Blackpool350ZCS Posted July 26, 2021 Share Posted July 26, 2021 Hi my 350z has a steering judder, mainly when it’s slow or on the spot. It also goes through power steering fluid. No visible leaks. Does anyone have any idea? Is this a common fault? thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 26, 2021 Share Posted July 26, 2021 If you are using pas fluid then there must be a leak and low fluid or air in the system will give you a judder Quote Link to comment Share on other sites More sharing options...
Blackpool350ZCS Posted July 27, 2021 Author Share Posted July 27, 2021 Thanks, the leak is the hard bit to find, doesn’t want to present itself anywhere Quote Link to comment Share on other sites More sharing options...
Blackpool350ZCS Posted July 29, 2021 Author Share Posted July 29, 2021 Well, news on this. Tried removing the fluid and a can of stop leak back in, top up, remove air and so far so good. May have just been poor quality fluid Quote Link to comment Share on other sites More sharing options...
