Loadmaster Posted June 14, 2021 Share Posted June 14, 2021 (edited) I usually use a minimal amount of white spirit, followed by a thorough wash after I've got the stuff off. However, that's been for 'regular' alloys, not diamond cut lacquered ones. All four of my Rays on my Nismo has this cack, so what's the best and safest thing to use? Cheers! Edited June 14, 2021 by Loadmaster Quote Link to comment Share on other sites More sharing options...
Stutopia Posted June 14, 2021 Share Posted June 14, 2021 If you can soak it in tar and glue remover, using a makeup pad or similar to force it to sit on the area, that might work. Maybe a plastic razor blade too? 2 Quote Link to comment Share on other sites More sharing options...
alexgv1 Posted June 14, 2021 Share Posted June 14, 2021 I’ve just tried Koch Chemie Eulex on mine, using a partially soaked microfibre and several passes. It’s the best thing I’ve used for removing wheel weights so far. 2 Quote Link to comment Share on other sites More sharing options...
Loadmaster Posted June 14, 2021 Author Share Posted June 14, 2021 50 minutes ago, alexgv1 said: I’ve just tried Koch Chemie Eulex on mine, using a partially soaked microfibre and several passes. It’s the best thing I’ve used for removing wheel weights so far. Thanks Alex, worth a punt I think. Just ordered some from Slim's Detailing. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted June 14, 2021 Share Posted June 14, 2021 3 hours ago, Stutopia said: If you can soak it in tar and glue remover, using a makeup pad or similar to force it to sit on the area, that might work. This. Rubbing with a microfibre will eventually shift it, but when using glue remover it's best to soak it in the stuff whenever you can. Saturate a cotton (or bamboo if you're bothered about the environment) makeup pad remover/paper towel (basically anything you can use to keep the area wet) and leave it to soak in for a few minutes first - just don't let it dry out! - then dab a bit on a microfibre and start rubbing. If it's not coming off freely go for another soak to make it easier. And remember to rinse thoroughly when done, you don't want glue remover to dry on the surface. Any glue remover should work (even AG in this instance) but if you've already bought Koch Chemie stuff you're all set. 1 1 Quote Link to comment Share on other sites More sharing options...
alexgv1 Posted June 15, 2021 Share Posted June 15, 2021 On 14/06/2021 at 16:42, Loadmaster said: Thanks Alex, worth a punt I think. Just ordered some from Slim's Detailing. Good luck, I’m sure it will be up to the job 1 Quote Link to comment Share on other sites More sharing options...
W8BGS Posted June 17, 2021 Share Posted June 17, 2021 I had the same problem recently after changing all 4 tyres. I found Autoglym intensive tar remover, a cloth and an old debit card. It took a while, but worked well. Quote Link to comment Share on other sites More sharing options...
SPAXY Posted July 21, 2021 Share Posted July 21, 2021 brake cleaner works well,pre soak the glue residue first it with a soaked cloth or pad then,wipe over or use plastic scraper or the rubber headed air tool that sealey make,that soon shifts it. Quote Link to comment Share on other sites More sharing options...
SPAXY Posted July 21, 2021 Share Posted July 21, 2021 (edited) sealey stripping tool Edited July 21, 2021 by SPAXY Quote Link to comment Share on other sites More sharing options...
