Jinshim Posted May 7, 2021 Share Posted May 7, 2021 Hi all, Currently in the process of buying a new battery for my car, I'm unsure of the cold cranking amps for the car + the hourly amp rate. I've got an aftermarket head unit in the car. The few battery sites I've tried the terminals are the wrong way round and I don't want to stretch the cables too much. When I popped into Halfords they weren't much help either. Thanks! Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted May 7, 2021 Share Posted May 7, 2021 When I swapped out on my old 350, the Bosch S4 was the battery of choice. Had more than enough on the CCA side of things so should be fine on a 370 too. Others may have more accurate help but i'd use the S4 as a guideline Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted May 7, 2021 Share Posted May 7, 2021 (edited) Take your pick: https://www.tayna.co.uk/car-batteries/types/005r/ Stick your reg in and double check, but pretty sure any of those will do you - personal choice would be a toss up between the Bosch or the Varta though. Failing that; https://www.tayna.co.uk/tools/battery-wizard Edited May 7, 2021 by ilogikal1 ETA wizardry. 1 Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted May 7, 2021 Share Posted May 7, 2021 I've got a Bosch S4 that's been going strong for over 8 years!!! My zed is used daily so I suppose that helps, but I'm getting another when mine dies. 2 Quote Link to comment Share on other sites More sharing options...
