Afternoon all. Last year I picked up a blue soft top 350z which had been looked after. It had the window switch issue on the passenger side where it would some times go up and if it doesn’t you had to wait a while and eventually it would go back up (normally this would happen after putting the roof down and then back up when required) I read on forums such as this that it’s an easy fix yourself or not to expensive if you get a garage to do it etc.
over the winter I didn’t start my car as much as I should and the battery went. After a couple of months, I recently replaced the battery and the window switch thing doesn’t  seem to be an issue any more! So I am just wondering if there is any chance the battery replacement ‘re set’ anything or if it’s still going to be an issue probably in the future and I have just been lucky at the moment? 😃
