Lynchyy Posted March 29, 2021 Share Posted March 29, 2021 Anybody got any tips to diagnose this? The feed going into the front wipers is not getting any water. just wondering before I start stripping the car down if there is a common problem? Quote Link to comment Share on other sites More sharing options...
bluethermal Posted March 29, 2021 Share Posted March 29, 2021 If the pump is running then its the one way valve. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 29, 2021 Share Posted March 29, 2021 Let's assume you've filled the system to the brim ? Quote Link to comment Share on other sites More sharing options...
Lynchyy Posted March 29, 2021 Author Share Posted March 29, 2021 Yeah system is full. I haven't checked the pump runs actually. Great shout. Quote Link to comment Share on other sites More sharing options...
marzman Posted March 29, 2021 Share Posted March 29, 2021 Trace the pipe back from the bonnet spray jets to under the front windscreen cowl. There will be a Y shaped 1 way valve which gets blocked. I replaced mine with a Bic Biro pen lid for a fe months and it worked perfectly. Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted March 29, 2021 Share Posted March 29, 2021 Check that you can hear the pump running would be the first point of call I’d say, it’s behind the front right wheel splash guard behind the bumper. Quote Link to comment Share on other sites More sharing options...
Mikey_S Posted March 29, 2021 Share Posted March 29, 2021 If you take the T pipes off the wipers, do you still get water out of them? When I refurbed my wipers the jets packed up, turns out they were full of crud so I spent a whole afternoon (really!) Pumping hit water through them with a syringe, blowing them through with compressed air and digging crud out with a stripped down paperclip Worked perfectly after that Quote Link to comment Share on other sites More sharing options...
Lynchyy Posted March 31, 2021 Author Share Posted March 31, 2021 Thanks for all the info. Looks like its a pipe blockage from the pump to the front screen, as ive swapped over the rear and front tube at the motor side (so technically when i press the rear, it should now operate the front) but it still doesnt work. Tried to blow compressed air back through the jet and no bubbling at the tank. I will buy from wash piping and re-route i think. Quote Link to comment Share on other sites More sharing options...
bluethermal Posted March 31, 2021 Share Posted March 31, 2021 If the one way valve is blocked swapping the pump feed isn't going to make a difference. Quote Link to comment Share on other sites More sharing options...
Lynchyy Posted April 3, 2021 Author Share Posted April 3, 2021 Ahh ok. Thanks for the info. Where about a is the 1 way valve situated? Quote Link to comment Share on other sites More sharing options...
bluethermal Posted April 3, 2021 Share Posted April 3, 2021 Open the cover over the brake fluid reservoir/servo and et voila. 1 Quote Link to comment Share on other sites More sharing options...
