Mikey_S Posted March 14, 2021 Share Posted March 14, 2021 Hi, hoping someone can advise on the below... Always seems to be something wrong at the moment. My clutch pedal when lifting off makes a loud squeak which is audible outside of the car. Clutch seems to be operating ok but it also makes a clunky noise but pretty sure it's been there since I bought the car. Short video below. https://youtube.com/shorts/vBg8ryjbEV0 What do you reckon? Thanks Mike Quote Link to comment Share on other sites More sharing options...
evilscorp Posted March 15, 2021 Share Posted March 15, 2021 if its an external slave cylinder I would pull back the rubber boot and add some grease, i find once the slave is old the water gets in and it starts to squeak then fail. Quote Link to comment Share on other sites More sharing options...
Mikey_S Posted March 15, 2021 Author Share Posted March 15, 2021 (edited) thanks for the advice. Yes I've a rev-up so its external. Can you get to the slave without jacking the car up? I've got a replacement slave kit I purchased from Tarmac when they had an offer on but didn't want to swap the slave until I did the clutch and flywheel. WD40 good enough to grease it? Edited March 15, 2021 by Mikey_S Quote Link to comment Share on other sites More sharing options...
