VDC switch not working?
Josh350
Hi guys.
I've recently bought my first 350z, a Japanese import 35th anniversary edition. Loving every second of it so far.
Been ticking off a few jobs from the list, and next is... The VDC switch doesn't seem to work.
Once pressed (and/or held down) it doesn't do anything as far as I can see. No light on the dash. That said, once the car is started up before the engine is startee the light doesn't come up on the dash either.
I've checked the fuse which is fine but am stumped as to what to do next.
Is this a common problem? Am I missing something obvious?
Thanks.
If you do not have the equipment or required skills to check out the electrics, i would firstly just try another switch.
Is the VDC locked on or off?
Switches and any other required parts to fix your issues are in stock if required.
I don't think it's locked on as there's no light showing on the dash. Nor is the light on when starting the engine.
How would I go about changing the switch? Literally pull the one out, reconnect the new one and keep my fingers crossed for a response?
Thanks for your help 👌
