Daz77 Posted February 12, 2021 Share Posted February 12, 2021 Hi all. I own an Elgrand 3.5L which I believe is the same engine as a 350Z (VQ35DE). I have a whirring noise which sounds metallic when the engine is idling (relatively loud). An experienced mechanic (with Elgrand’s) has looked at it but is stumped as to what is causing it. He has taken off the belt but the noise remains. It doesn't make the noise from cold but will start after about 5 - 10 minutes. My mechanic has suggested it could be the water pump and I understand there's a way of changing it without taking the chain off therefore not risking any timing issue. They have never had to change one before and don't want to have to take the chain off so I'm looking at any advice to pass on to them. I'm reluctant to drive it anymore. If anyone has any idea as what is causing this sound I'd really appreciate your comments. This is the noise: Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 13, 2021 Share Posted February 13, 2021 Impossible to provide an informed diagnoses from just the video I am afraid as there are procedures to follow to trace the noise with the engine running. It is obviously rotational and my comments are below. Is your car manual or Auto? Did your tech remove both belts? Has he checked the position of the hydraulic main chain tensioner and the condition of the associated tensioner/slipper/guide? The water pump, which is chain driven, can be replaced without removing the timing chain cover, but you have got to be careful that the chain does not slip or jump a tooth, but if the procedure is followed to the letter, then this will not happen. All the above are very straight forward and any competent tech who knows his way around a VQ35DE engine should have no difficulties carrying out the above. Alex. Quote Link to comment Share on other sites More sharing options...
Daz77 Posted February 13, 2021 Author Share Posted February 13, 2021 Hi Alex and thank you for your reply, I really appreciate it. My car is an automatic but I'm not sure the answers to your other two questions. I will most certainly pass on your comments to the tech. As I don't know what is causing the noise I am reluctant to drive it as I don't know if I'm doing any damage which could lead to a serious problem. Talk about being stuck between a rock and a hard place! Daryl Quote Link to comment Share on other sites More sharing options...
Daz77 Posted February 17, 2021 Author Share Posted February 17, 2021 (edited) Problematic noise fixed!! Turns out it was a faulty oil filter - the valve inside was the issue. Replaced the old Blue Print for a better quality HKS filter. Thanks to Alex for your reply to my message. Edited February 17, 2021 by Daz77 Quote Link to comment Share on other sites More sharing options...
