Ceejay29 Posted February 2, 2021 Share Posted February 2, 2021 Hi guys, The protective corrosion coating applied to the rotors (believed to be that)....I’ve recently read that this should be removed prior to road use. I presumed the bedding in process would remove the coating naturally? Although it would clog up my new pads. Please could someone advise. Thanks Chris Quote Link to comment Share on other sites More sharing options...
Jack94 Posted February 2, 2021 Share Posted February 2, 2021 (edited) After you've touched the brakes a couple of times that coating will be all gone on the contact area, with no harm to the pads. Never heard of anyone removing the coating prior to fitment. Edited February 2, 2021 by Jack94 2 Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted February 2, 2021 Author Share Posted February 2, 2021 Thanks, my thoughts exactly. How on earth would you even begin to remove it without damaging the surface. Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted February 2, 2021 Share Posted February 2, 2021 I have drilled and grooved ebcs on mine, the instructions state nothing of the sort, they give you normal instruction to go easy for first couple hundred miles then do a few harsh emergency stops from about 60mph, should be in the instruction manual. 1 1 Quote Link to comment Share on other sites More sharing options...
BigPoch Posted November 8, 2021 Share Posted November 8, 2021 you bed them in during your first energetic drive Quote Link to comment Share on other sites More sharing options...
