James Scott-Stacey Posted January 18, 2021 Share Posted January 18, 2021 Hello, Might not have asked this in the right place. Wondering if anyone has any suggestions for a decent ball joint press for these 350s. Need to get mine sorted, and figured I'm better off getting the correct tool to start with. Cheers Quote Link to comment Share on other sites More sharing options...
Kevlaar Posted April 9, 2021 Share Posted April 9, 2021 Also interested in this if anyone has any good links. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 9, 2021 Share Posted April 9, 2021 I use a commercial hydraulic press in the shop for all press work. What ball joints are you referring to. Mostly any press will will be suitable for ball joint press work, however, you will require compatible plates/cradles depending on the application. Like all press work keeping the unit square is key. Quote Link to comment Share on other sites More sharing options...
