Re-body My Zed
Falcata
You should be filming this and putting it on a Youtube channel.
Check out B is for Build - you could do videos in their format - i.e. a few mins of commentary describing what you're going to do each day, and then just filmed from a static camera position on time lapse.  Would make compelling viewing.
Edited by marzman
  • 3 weeks later...
Hi Marzman
I have been working on a possible sponsorship for a YouTube channel I would love to do that , but one of my biggest problems is time !!! so if a company wants to help me out with products i need or tools to help speed up the process  , i would be all over it , helping them promote and showcase their tools or composites and how to apply them , I am just a regular guy doing this build on my own , it's tough enough , it takes time to film and edit , post etc .
I did a few tech tip vids all my buddies like them , but it takes time away from the build .
Even the time it takes to update the 3 sites I have this build on sometimes is a struggle to squeeze it in.
It's awesome you think it's worthy , nice to know I am not the only one that likes it .
And I would like to thank everyone again for all the positive feedback , it really helps !!
Thanks everyone for fallowing along and the fantastic positive feedback .
Been busy as usual , had some crazy heatwave here last weekend , 4 days with temps in the high 30's .
Also did something nasty to my knee , that's slowed me down a bit can only do stuff standing , it's getting better ... very slowly , 30 years of racing motorcycles didn't help .
been working on the trunk lid and the hood ,
will start with the hood .
This bottom of the hood started out as just a test in the new shop to test the waters , I had a couple of gallons of resin that were really old and had probably been below the 45 degree limit . so i did a copy of the bottom of the stock hood , this would give me a look at where i could make more room foe goodies . I had to trim a bunch for the fenders , so as time went along I decided to use it .
Now I need to extend the back of the hood ,these pieces are just to support the the part for the fiberglass .
Making the part to slide under the back to hold up the extension
once glassed it will get trimmed at the blue line , you have to go past to get a consistant thickness
checking  supports  to see if it's still level
Here is the part sanded to a taper to slid in , the plastic part behind will go on top so the glass wont stick to the support .
roughing up the glass for a good bond
getting ready to bond it down
holding it down , I use body fill to glue the two pieces of foam together .
next is to add a little filler to smooth the transition
 then three units of mat
another strip of plastic to avoid it sticking and some wood and squeezie clamps
Oh the other thing I should mention is I bought a 3D printer to make some parts for the car , oh course i have have to learn how to use it first , ( more time , later nights )
So I bought a Creality CR10 V3
I have been working on drawings for the emblems and a Crest  ( badges )
so far so good  .
I have to rearrange some stuff  in my office for It .
It will print 400 x 400 x 600 mm
The verity of filament is ridiculous , I can print these in chrome or black chrome or any combination of colors  , I have to learn CAD again .....not easy  .
this is the first one , needs tweaking
just an idea of what it would look like , of course it would be set in flush
And on the hood .
times up . maybe tonight i can post some pics of the trunk lid progress .
Cheers Mates
  • Like 5
Ok  back to the hood , I know it's kind of boring .....
So here is how the hood extension came out  , a little wavy at the back in the middle . but that will be cut off .
I don't want to see the wipers , they are just not nice to look at .
Making the small rise out of foam for the wipers to fit under
gluing it down
Some body filler , then one unit of mat and one unit of roving , covered by two units of mat glass .
the roving gives it strength
I mixed a bit too much resin ( heat getting to my brain ) so I added some filler and painted it on the fender  .
Glass ready for a trim
Hood is upside down here to cut the bottom away and remove the foam .
Trimmed and back on
Look no more ugly wipers ..
Here you can see when the top of the hood goes on the rise will be very small
I have been working on the trunk and rear deck also , should have an update on that soon .
Cheers
  • Like 5
And once again thanks gents for the kind words , you make me out to be some kind of wizard !! . thanks so much it really does help to get through the dark times , dragging my butt , scratching my head thinking how do i do this next bit.
So sorry to say more boring stuff for now .
First the hood latches .
Earlier on I made provisions for the latches to go .IMG_20210713_144150369.jpg.2fb2bb5dd898146bd571bbadea609a6e.jpg
I used the radiator mount for the latches , so it's easy to drill in the right place for the hood latch pins .
This is still the bottom part of the hood , so I needed to cut the holes for the latches , and then cover them , so once the lower hood is molded I will know where to cut out the holes for the latches .
  • Like 3
Hi
I must apologize for the last post , I started way too late and was falling asleep ....
So here we go .
back to the back of the car .
Here you can see body working in the Batman humps , I glued the two wooden bucks back on and used the laser to find my intersecting point where the quarter and the deck meet .
once the deck lid is set in stone so to speak , i will trim the trunk lid to fit
I put tape on just to see how things are shaping up , the tape doesn't show all the curves but it helps .
can't wait until the roof is finished and I can foam the quarter panels in !!
well that it for today , off to the shop to do some more .
Cheers
  • Like 6
Hi everyone
Another update
I have been working on emblems and crests with my 3D printer
Onto the quarter panels .....I have lost a lot of time this past couple of weeks with helping people etc .
here I am using the laser in lock mode , which means it won't self level , it's a great feature .
You can set an angle , i am using the angle finder so i can repeat on the other side , plus putting insurance marks on the wall .IMG_20210726_150250882.jpg.b33122680b2a34e608e09530a7613cb4.jpg
here I am interlocking the bucks together so I can keep the shape and make it strong enough to work it with tools once filled with foam
Here I am laying out the cut with a baton , I an I will copy the part for the other side before gluing it in place .
I am getting excited again , seeing some progress .
  • Like 9
Another update
Working on the quarter panels .............gotta get this car done !!!!
Gas fill door , will be using the factory lid , made the quarters to match the shape .
cheers for now ............
  • Like 2
