da.murf Posted January 11, 2021 Share Posted January 11, 2021 Hi guys so last June I had a @Tarmac@TarmacSportz rivet-less ducktail fitted by a body shop they also smoothed and painted my front bumper. finish and match of Bumper is perfect. Spoiler was also great until maybe September. Then small blister/bubbles started to appear. photos below : please note this photo was September. There are many more now. I though they could be air filled, from maybe pours in the fibreglass. They where inspected by painter today and when we pierced one it was full of water. when we fitted Spoiler afaik It was correctly primed etc etc the original spoiler holes Where Left unsealed under the new ducktail to allow air movement etc. help guys.... it’s getting sorted next month but at a loss of what could have caused it? could damp air from car sitting have gotten up under the spoiler through the original spoiler holes and dampened it from below etc ?? really need forums help on this one lol Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted January 11, 2021 Share Posted January 11, 2021 Could be a number things that caused it; excess moisture under the paint, using the wrong primer or the surface not being cleaned properly. Excess moisture might be the more obvious suspect - check to see if there’s any obvious signs of moisture getting in from underneath - but it could be the way/what was applied; either way take it back to the body shop that painted it and get them to look at it. Quote Link to comment Share on other sites More sharing options...
da.murf Posted January 11, 2021 Author Share Posted January 11, 2021 Just now, ilogikal1 said: Could be a number things that caused it; excess moisture under the paint, using the wrong primer or the surface not being cleaned properly. Excess moisture might be the more obvious suspect - check to see if there’s any obvious signs of moisture getting in from underneath - but it could be the way/what was applied; either way take it back to the body shop that painted it and get them to look at it. see that's why I wondered if the oem spoiler holes should have been sealed? Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted January 11, 2021 Share Posted January 11, 2021 It’s a possibility, but I suspect less likely as the water would have to travel through the spoiler to get under the paint where the bubbling is. I wouldn’t rule it out entirely without further investigation though. Quote Link to comment Share on other sites More sharing options...
Olly350z Posted January 11, 2021 Share Posted January 11, 2021 Possible that the bodyshop used a thin layer of filler for a smoother finish which they've left exposed during prep which has absorbed moisture? Just an idea, probably wrong however I find it suspect its the majority of the spoiler. If it was one area I'd say its a reaction but not the entire way along Quote Link to comment Share on other sites More sharing options...
