350z Banana Arm replacement
joel44w
Hi ,
Can the Banana arm be replaced on one side (passenger side rhd uk) without having to drop the whole front subframe brace ?
As im going to be doing this at home on the ground and thought it might be a bit awkward to do without a lift...
Think i might already know the answer for this :lol:
TIA!
You'll need to take the whole brace off really, but that's only about 6 nuts/bolts? If you don't you'd be bending it out the way very severely to get the compression arm bush off the stud. The stud is very long.
You'll want to put it on stands on the under side chassis rail seams both sides and get it up about 2 foot in the air to get under and get the brace off etc.
It's not a difficult job really when compared to trying to do a ball joint on the driveway when there's limited space to get both a gun and C-clamp under the car without the ground fouling.....
