miller_350 Posted December 21, 2020 Share Posted December 21, 2020 Hi, Would a Greddy Oil cooler fitted result in lower oil pressure than without one? Cheers Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 21, 2020 Share Posted December 21, 2020 Only if your oil is low, but I’m assuming you topped that up during the install. How low is the pressure? I mean you could see a fractional pressure drop if the new pipe work is significantly longer than the old and the oil pump is worn, but I’m grasping at straws here. Really there should be no difference in pressure at all. Quote Link to comment Share on other sites More sharing options...
miller_350 Posted December 21, 2020 Author Share Posted December 21, 2020 Thanks for your reply. Oil level is fine. I am having issues with the oil pressure sensor (auto gauge aftermarket one). When warm idle it says nil but mechanic has confirmed it's fine and on 15 psi. I have changed the switch and sensor but the same. I just thought maybe the oil cooler would make it lower and sensor isn't accurate hence warning light comes on. It is intermittent to even register a reading so must be wiring or maybe the gauge itself. Cheers Quote Link to comment Share on other sites More sharing options...
Ian Posted December 21, 2020 Share Posted December 21, 2020 Cheap gauge, I've had cheap ones in the past & they never work properly. Gives a right scare when your oil pressure suddenly drops to zero and your 150 miles from home Best off with a Defi/Greddy gauge, they are pricy but they work so well :) Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 21, 2020 Share Posted December 21, 2020 Agreed, sounds like the gauge to me. Bin it and try something better. Quote Link to comment Share on other sites More sharing options...
miller_350 Posted December 21, 2020 Author Share Posted December 21, 2020 Thank you both, was just about to spend £95.00 on a replacement from eBay! It also has auto gauge water and oil temp alongside it (the volts had been moved) so I assume I need to replace all three together? Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 22, 2020 Share Posted December 22, 2020 Up to you, but if you can’t trust one would you ever trust the others? Quote Link to comment Share on other sites More sharing options...
miller_350 Posted December 22, 2020 Author Share Posted December 22, 2020 True, they do work but suppose difficult to tell how accurate they are. I thought they might be linked and had to replace all three if changing to a different make. Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 22, 2020 Share Posted December 22, 2020 As has been said, cheap gauges will be your demon. PM on its way. Quote Link to comment Share on other sites More sharing options...
