Eibach rear camber and toe bolts
Rob332
Hi guys,
My rear adjustment bolts are in need of being replaced.
Is the Eibach rear alignment bolt kit a straight fit, or are any modifications required to get them to fit ?
http://www.clarkmotorsport.co.uk/parts/Eibach-Rear-Camber-and-Toe-Bolt-Kit/5.72055K
I've read that with some bolt kits the holes need elongating. I just need a kit that will replace the oem bolts.
Much appreciated
Yes, the Eibach kit gives you the extra adjustment required when you require to dial the geometry back into spec after lowering etc. and a template is included in the kit for you to do this.
If you simply require a kit to replace like for like with no cutting or drilling, then I have these in stock and good to go same/next day.
Just drop me a PM if I can help further.
