skyrapier Posted November 14, 2020 Share Posted November 14, 2020 Unsure if anyone can help me, but my drivers side door is completely jammed/locked and does not open from the outside nor from the inside. So I've been climbing through the passenger door like a loon. I tried unlocking with the physical key but no luck. As a note, when turning the key to the left, you can feel little resistance, but I didn't want to force it or damage anything. The door handles themselves operate normally, the exterior button on the handle seems to lock/unlock all the other doors except this one. Made a booking with Nissan for the 23rd. However, its worrying because prior to this issue, sometimes the passenger door would fail to open too, but this is only from the outside. (There were times I have to open the passenger door from inside so my wife can get in). So I mentioned this to Nissan and they said they'll check both of the doors. It would be a terrible situation if I can't gain access into the car at all. Or even worse, being stuck inside the car and having to climb out the window lol. Unfortunately Nissan do not have an earlier booking date. Wondering if there's a solution to this before I pay £50 for a diagnoses check. Anyone had the same issues or know a solution? Would greatly appreciate it. Thanks guys! Quote Link to comment Share on other sites More sharing options...
LRF4N Posted November 14, 2020 Share Posted November 14, 2020 Brings back memories of going through the passenger door in mine Common problem in winter. With mine the mechanism had seized. Had the door card removed, mechanism lubricated, never had the issue after that Opening the door needed the door hanger trick 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 14, 2020 Share Posted November 14, 2020 You will probably find that the rod has come adrift from the blue plastic clip or that the clip it self is broken which is an easy fix. The tricky bit is getting the door open so you can remove the door card. https://www.wikihow.com/Use-a-Slim-Jim 1 Quote Link to comment Share on other sites More sharing options...
