galaxyg Posted October 15, 2020 Share Posted October 15, 2020 On the second/longer pull of the lever it just kind of dribbles out. First pull little or nothing. Headlight washers blast out plenty, I can see it in the air. Any ideas how to solve? Quote Link to comment Share on other sites More sharing options...
Jack94 Posted October 15, 2020 Share Posted October 15, 2020 From what I understand after a quick look on here (someone please correct me if I'm wrong)... Our cars have 2 washer tanks, 1 each side behind the front bumper. The RH one has 2 pumps- for the front/rear screens & the LH one has 1 pump- for the headlight washers. I'm which case you could either have a blockage in the pipe or the pump motor might be dead. To test the motor just put 12V to it, and to test if the pipe is clear just try blowing some air through it with an airline. Quote Link to comment Share on other sites More sharing options...
bluethermal Posted October 15, 2020 Share Posted October 15, 2020 Don't forget to check the one way valve under the scuttle. Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted October 15, 2020 Share Posted October 15, 2020 Hi Mate, as jack said 2 pumps one for headlights one for screen, has the car been sat for a while? We get so many customers saying the washes don’t work and that’s usually because the screenwash additive goops up and blocks the gauze in the motor, can you hear the motor working? buzzing behind the arch liner? if so no need to check the fuse but by the sounds of it it’s really weak, might be worth checking all the pipes for blockages or kinks like jack said, sometimes the actual pipe gets shut in the bonnet so it bottle necks it, if the pipes all seem fine and clear get a needle and or blower and blow through the actual jets themselves, hope this helps Quote Link to comment Share on other sites More sharing options...
galaxyg Posted October 18, 2020 Author Share Posted October 18, 2020 Hi All, Thanks for the advice so far. After about 20 mins of investigation I've got as far as knowing what it is not. The nozzles themselves are clear. Also, if I blow compressed air into the rubber pipe on the passenger side, the water in the tubes will shoot out the wiper on the drivers side until the tube is empty (although not the other way around..). And almost needless to say, I've checked water tank is filled up. The car was not used much for a few months from March-Jun and then even after that, I didn't use the wiper much as it was summer. The motor is working I can hear it and it does have the effect that the water does dribble out the drivers side and comes out the passenger side slightly less pathetically, about a 4cm length squirt. >Don't forget to check the one way valve under the scuttle. Is that something I have to remove the scuttle to get to? Excuse me if that's a novice question. I don't normally do car maintenance myself. Michael. Quote Link to comment Share on other sites More sharing options...
bluethermal Posted October 18, 2020 Share Posted October 18, 2020 Open bonnet, lift up brake fluid reservoir panel and its right in front of you above the brake servo. Quote Link to comment Share on other sites More sharing options...
galaxyg Posted November 15, 2020 Author Share Posted November 15, 2020 On 15/10/2020 at 16:05, bluethermal said: Don't forget to check the one way valve under the scuttle. Turns out it was that. Replaced it and it all comes out good as new. Thanks. Quote Link to comment Share on other sites More sharing options...
Mikey_S Posted November 15, 2020 Share Posted November 15, 2020 How did you swap it? I struggle to remove mine, where did you get a replacement? Quote Link to comment Share on other sites More sharing options...
bluethermal Posted November 15, 2020 Share Posted November 15, 2020 When you locate it simply pull washer pipe from the valve and replace making sure the direction arrow is pointing the right way. Hafrauds, motor factors or ebay for £1.80 ish, easy peasy. 1 Quote Link to comment Share on other sites More sharing options...
galaxyg Posted November 15, 2020 Author Share Posted November 15, 2020 9 hours ago, Mikey_S said: How did you swap it? I struggle to remove mine, where did you get a replacement? Replacement came from Halfords - a one way valve or a simple hose joiner will do the job. For anyone's future reference : Open up the brake fluid cover (Left hand side of engine bay if you're standing at the front of the car - it's the symmetrical opposite from the battery bay). Once that is open you can reach under the scuttle panel and it's really not very deep inside. Black hose on the left (which eventually goes to the reservoir) and then the white one-way valve and then a transparent (or mine was semi-pink, perhaps stained) on the right. I was able to pull off the black hose with my hands, and the transparent one I needed pliers to get a better grip. 1 Quote Link to comment Share on other sites More sharing options...
