Rajtastic Posted September 25, 2020 Share Posted September 25, 2020 Hi guys Changing to Konis on my 110k mile 350Z and was going to do some general maintenance at the same time. I took my Z to Abbey a couple of years ago and they recommended a load of bushings to change (which I've switched to White Line already) - is there anything obvious you think I should change? Here's the list of stuff I've bought so far - it's basically any nut/bolt I'll touch during the install plus some of the bushings in the suspension bit itself (wasn't going to change the metal mounts - I figured they can't degrade much surely)? Any other suggestions/misses? Cheers, Raj Tastic Quote Link to comment Share on other sites More sharing options...
Eddie_r32 Posted September 27, 2020 Share Posted September 27, 2020 Have you replaced the rear lower shock bushing as the oem ones can weld themselves to the bolt which is always a fun time Quote Link to comment Share on other sites More sharing options...
Rajtastic Posted September 27, 2020 Author Share Posted September 27, 2020 10 hours ago, Eddie_r32 said: Have you replaced the rear lower shock bushing as the oem ones can weld themselves to the bolt which is always a fun time Cheers for the tip - I think I've ordered what you're referring to? I also email Koni and they said that there's prob no need to replace any of the mounts (i.e. the bits made of metal) so just the rubbers should be good. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 27, 2020 Share Posted September 27, 2020 This is the bushing that Eddie is referring to: 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 27, 2020 Share Posted September 27, 2020 Quote Link to comment Share on other sites More sharing options...
Rajtastic Posted September 27, 2020 Author Share Posted September 27, 2020 41 minutes ago, ZMANALEX said: Ah - sorry, I'd misunderstood. You mean this guy? 1 Quote Link to comment Share on other sites More sharing options...
Rajtastic Posted September 27, 2020 Author Share Posted September 27, 2020 In fact, just realised OEM bushing are half the price. Reckon I'll notice any difference? I've got whiteline poly bushes elsewhere but those are all parts which didn't come with a bushing pre-installed (i.e. someone had to press the old rubber ones out). Quote Link to comment Share on other sites More sharing options...
