Blackstar Posted September 20, 2020 Share Posted September 20, 2020 I'm looking to replace my fairly badly corroded OEM cats (suspect cause of P0430 code and nasty sound) with something stainless. I'm not bothered about sound and would be looking for something that would fit into the OEM position. I was wondering if anyone had any recommendations? Quote Link to comment Share on other sites More sharing options...
Ekona Posted September 20, 2020 Share Posted September 20, 2020 Only guarantee I’d ever make is a second hand set of OEM cats. Every other solution runs the risk of CEL and/or failing MOT, and at that point you might as well get the only thing that will definitely work. 1 Quote Link to comment Share on other sites More sharing options...
Jack94 Posted September 20, 2020 Share Posted September 20, 2020 Agreed, if you're not bothered about a noise or power increase HFCs might cause more hassle than they're worth. To guarantee you won't get the warning light pop up you'd need a remap to turn the rear O2 sensors off (£400), plus you'll always have the worry of passing the emissions test unless you know a "friendly" tester. @ZMANALEX might have some second hand oem cats available. 1 Quote Link to comment Share on other sites More sharing options...
MDMetal Posted September 21, 2020 Share Posted September 21, 2020 12 hours ago, Jack94 said: Agreed, if you're not bothered about a noise or power increase HFCs might cause more hassle than they're worth. To guarantee you won't get the warning light pop up you'd need a remap to turn the rear O2 sensors off (£400), plus you'll always have the worry of passing the emissions test unless you know a "friendly" tester. @ZMANALEX might have some second hand oem cats available. Nothing wrong with secondhand cats when I bought the z originally and the cats needed replacing I did get the Berk HFCS they've never had any issues with the test and it's had about 6 mot's with me at different garages so no winks or nudges needed. I did get the warning light a few times but since replacing the rocker covers last month so far the light hasn't come back so perhaps the light is triggered by oil in the exhaust. Either way second hand is fine and the Berks (or similar) have the exact same fitment. They sound nicer and from new cost less 1 Quote Link to comment Share on other sites More sharing options...
Blackstar Posted September 21, 2020 Author Share Posted September 21, 2020 Thanks all, assuming mine are original, then they are 16 years old on 91,000 miles. Dare I ask what do you think I would be looking at for a pair of new ones from Nissan? Quote Link to comment Share on other sites More sharing options...
MDMetal Posted September 21, 2020 Share Posted September 21, 2020 2 minutes ago, Blackstar said: Thanks all, assuming mine are original, then they are 16 years old on 91,000 miles. Dare I ask what do you think I would be looking at for a pair of new ones from Nissan? More than you'd want to pay :P Seriously the OEM stuff is more than the aftermarket parts which sound nicer, I said I'd just keep it stock but as soon as bits fail your better off buying something fun and cheaper thats just as good if not better quality. 1 Quote Link to comment Share on other sites More sharing options...
