25mm Shortened 370z Knuckles
Silverthorn
Hi all,
Up for sale are my 25mm Shortened 370z Knuckles. These had 25mm of the knuckle removed and the two seperate pieces were drilled and tapped to accept a 10mm stainless rod. They were then screwed together and TIG welded to finish.
The knuckle modification was done by Cadwell Engineering in Temple Cloud and the final TIG welding was done by a welding specialist at DS Machining Services in Yate.
These will reduce the angle that your front upper control arms sit at while driving. They'll therefore give you greater UCA to suspension turret clearance (great for stupid static ride heights like mine or if you want to air out that extra inch lower!) and reduced camber gain under compression.
Original thread here.
Collection from Bristol preffered. I can post these but they do weight a good 7 or 8kg so don't expect the postage to be cheap!
£250 £200 ono
Cheers,
Tom
IMG_20200501_103751.jpg.9f07457340093d81c986ca500f706ea7.jpg.765175340a067342bae4d993711d935a.jpg   IMG_20200501_111559.jpg.3a698b0a9fe69bf45224ed806c65131a.jpg.fc6fdc92d1adaa00d317d83f968ba024.jpg
Edited by Silverthorn
  • 2 months later...
  • 9 months later...
