Turn Key Drift 350Z
StevoD
Think its finally time to let the drift dream die :mellow:
For sale:
2003 Fairlady z Import (Registered in the UK 2006)
130k
Silver
Engine:
Limp mode tuning 4" intake,
NWP 75mm Throttle body
Plenum spacer
Decat
Stainless Y pipe
Japspeed exhuast
Uprev license tuned by abbey with the ARC License to allow burnouts/Left foot braking whilst under throttle,
Made 277 to the hubs on abbeys dyno
Suspension:
HSD coilovers 10k Fr/8k Rr,
PBM rear camber arms,
PBM rear traction arms,
PBM rear Toe arm,
Whiteline adjustable rear droplinks,
NIsmo Front ARB,
Nismo Rear ARB,
ISR lockout bolts
Driveline:
Lighten flywheel
KAAZ 2 way LSD,
Whiteline Diff bushings,
Dual Caliper brackets
Hydraulic Handbrake mounting plate,
Interior:
Cobra alarm/immobilizer,
80% stripped,
HKB boss,
Personal neo grinta wheel,
Corbeau forza sport seats,
Buddyclub rails,
luke 4 point harnesses,
Graffiti motorsport SCCA harness bar,
Hydro mount bracket
NRG quick releases Hub
Extras/notes:
New battery fitted,
Cobra immobilizer,
Car will come with 8 Rays wheels (including the ones fitted),
Car has always been ran on vpower/momentum since ownership,
Suspension Member Stay Brackets for rear subframe have just been replaced
Known issues:
Bodywork is a bit tatty from track/drift use
Gearbox is a early cd001 so has some synchro issues mostly around 5th gear,
No current MOT
£3990
Its more of a trailer turn key everything you need beginner drift car, but only some cats away from an MOT,
Private plate is not included, i will not pretend this is a concourse show car and many have seen on this forum this car has seen it used at drift days and track event, however the cars has been taken care of and areas where i felt a professional need to carry out work it has been taken to the likes of garage-d and abbey motorsport.
 If you plan to arrive and haggle over bodywork condition etc dont waste either of ours time.
Edited by StevoD
