Rear Camber Arm Kits for 30mm Springs
JAllen28
Just about to buy some Vogtland 30mm lowering springs and wondered if anyone can point me in the direction of some decent rear camber arm, toe bolts and lockout kits.  I can only find the tarmac sportz one at the minute.
Also what are people opinions on 30mm springs with 19" wheels? Any rubbing with 245/35 and 265/35 tyres?
37 minutes ago, davey_83 said:
Will depend on the wheel offset, you'll have issues with anything lower than et18 I would imagine. Fronts shouldn't cause an issue as the arches are rolled from factory.
Cool mine are 22 and 25 so should be okay! Any experience driving that low? I Be honest is it @*!#?
  • 5 months later...
On 02/09/2020 at 10:20, davey_83 said:
How mine sits now on -30mm Apex springs :hug:
this is lovely, what rear spats are those? Really look nice. Also what springs did you use? Currently looking to buy hence how I came across this photo 🥰
Thanks for coming back on this :) appreciate it. i'll have a gander for those spats. I think i'll likely be going with 18s unless i find a steal on some 19s ... so il probably go with some different springs.. From what I've seen lurking around the forum, for 18s a 20/25mm drop tends to be the key
