Help!!
MONKEYSOCKS
Moved the car out the garage 3 weeks ago to wash it, wax etc, put it back in the garage, put a new car cover over it as their can be alot of dust in the garage,which did seem tight, and just noticed that the front bumper has come away from the underside of the headlights by about half a centimetre?! Would this cause a problem with the locking mechanism in any way? Or is it just coincidence?
Its really up to you - if you can get to the battery then go for it although will there be fittings for the front bumper that are under the bonnet?
On my VX there is a separate battery back up for the locks, a button hidden away so that if you press the button and the key fob button it activates the back up battery and unlocks the doors, not sure if there is anything similar on the Zed. Have you tried reading the manual for the car?
