veeg33 Posted July 24, 2020 Share Posted July 24, 2020 Just been to groceries shopping, got in the zed and start up as per normal. As I drive, I noticed the oil pressure at 120 psi. I'm not sure if it was there when I first started my zed before going to the shops as I only looked at the RPM to drop to normal idle speed before setting off. It shots up pass 120 psi when I'm in gear and accelerate, dropped to 120 psi when idling. Got home, turn engine off and restart again, shoots up to 120psi again. No warning lights or any other signs, drives normal. Didn't notice the oil pressure since I last drove it 2 weeks ago. Oil + filter last changed in Dec 2019, driven less than 2000 miles since. I'm planning an oil change and filter change to see if this will resolve this. Anything else I should look at? Oil pressure sensor maybe? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 24, 2020 Share Posted July 24, 2020 Bad wiring, bad oil pressure sender, bad gauge. bad oil pressure relief valve. 1 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted July 24, 2020 Author Share Posted July 24, 2020 11 minutes ago, ZMANALEX said: Bad wiring, bad oil pressure sender, bad gauge. bad oil pressure relief valve. Champion! Quote Link to comment Share on other sites More sharing options...
Stewal Posted July 26, 2020 Share Posted July 26, 2020 Almost certainly the sender unit which is easily accessible to change and not too expensive - do not over tighten though. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 26, 2020 Share Posted July 26, 2020 3 minutes ago, Stewal said: Almost certainly the sender unit which is easily accessible to change and not too expensive - do not over tighten though. North of £80.00 for genuine Nissan OEM. Avoid cheap aftermarket. 1 Quote Link to comment Share on other sites More sharing options...
Stewal Posted July 27, 2020 Share Posted July 27, 2020 Would certainly endorse Alex's point about oem for the sender. With some parts its buy cheap pay 2 or 3 times over.......I speak from experience! Even a good used oem part will be better than a cheap ebay chinese copy. 1 Quote Link to comment Share on other sites More sharing options...
