[SOLD]FS: FI Parts
Ian
Power Enterprise Twin Turbo Kit
Comes with
PE1420 ball-bearing turbochargers (x2)
Custom turbo manifolds (x2)
Custom outlet pipes (x2)
High-capacity aluminum oil pan
Fuel pressure regulator
Air Impulse air intakes (x2)
Front-mount air-to-air intercooler
Inlet and compression pipe set
Oil lines
HKS SSQV
Kit is used, however there is NO play in the turbos.
The high capacity oil pan is included but not pictured.
You will need new gaskets, shorter manifold nuts/bolts or grind down OEM ones, new bolts for the intake pipes to connect to the turbos.
£3500 Collection only from South Wales, NP11
Berk Decat Pipes
The AFR wiring is not included in the sale.
SOLD
ARC Oil Catch Can
Super rare discontinued item, these sell new old stock for about £600 these days.
SOLD
APS Tallboy Plenum
Has been powdercoated black. Will need to either find an APS strut bar or run without one for this to fit
SOLD
Will have some more parts listed over the next few days (Cusco ARB, Nismo Floor Mats, 370Z BBK once I get around to photographing them)
Edited by Ian
