Clutch & flywheel replacement
Seb350z
Hi looking to get my clutch and flywheel replaced soon.(not causing as issues currently apart from the bite point is high) Car is on the original clutch 2004 model covered 56000, just looking to stay oem at the moment as this is my daily.
where is best place to purchase parts or best place that can supply and fit?
I am based in Cambridgeshire .
Thanks
The bite point is just high on the 350z, so if that's your only "issue" there's probably nothing wrong with your clutch.
If you were upgrading to aftermarket parts I'd see the point but if you're sticking with oem you might as well wait until it starts slipping to replace it.
The original clutch on mine has seen 65000 and still going strong.
