Please help the newbie!!
haylabamba
Hi All,
Looking at buying some new wheels/tyres for my 03 reg 350Z. They are:-
2 x Cruize 126 8.5 x 18
2 x Cruize 126 9.5 x 18
Tyres are 2 x 235/35/19 (Avon) and 2 x 265/30/19 (Avon).
2 questions, will I need spacers to fit over the Brembo brakes?
Any view/comments on this set up much appreciated.
Please not too techie with any replies :)
Many thanks
  haylabamba said:
Hi All,
Many thanks
would need to know the offset to comment further.
Thanks for quick replies guys, all I have so far is as follows.
2 X CRUIZE 126 8.5X18 ( FRONTS )
2 X CRUIZE 126 9.5X18 ( REARS )
2 X 235/35/19 AVON PERFORMANCE TYRES ( FRONTS )
2 X 265/30/19 AVON PERFORMANCE TYRES ( REARS )
1 X FULL FITTING KIT
1 X SET OF LOCKING BOLTS
1 X SET OF CHROME VALVE SLEEVES
THE WHEELS SIZE IS
8.5 X 19" 5X114 ET35 FRONTS
9.5 X 19" 5X114 ET35 REARS
Hi, mate! :thumbs:
The offsets dictate how far inside the wheelarch the wheel sits. High offset and the wheel is tucked in looking like a canoe on wheels (or an old E-type if you're being kind), low offset and the wheel and tyre could be sticking out of the arch, chav-Corsa style.
Its also dependent on width but perceived wisdom is that something in the region of a +18 to +25 offset will give you a nice aggressive look on the Zed without sticking out of the arches.
Your high offsets will not only look naff aesthetically but I suspect they will put the wheel too close to the brakes and may not fit.
Whilst we all want to be different (apart from the NISMO wheel boys ;) ) sometimes its best to select a wheel that has been fitted to a Zed before so someone else can make the mistakes for you.
Take a look at this website for some ideas or cruise our own wheel section. :thumbs:
http://www.zmodified.com/gallery/index.php?cat=31
Digsy and others. Thank you all for the great information. I have contacted the guy I was buying from and we will sort it by phone when I get home Friday. Hopefully I won't completely **** it up now and will make sure I upload some photo's post fitting
Once again thanks for the welcome and advice.
R
