Ceejay29 Posted June 6, 2020 Share Posted June 6, 2020 Hi, I am missing two o-rings for a set of 19 inch wheels I have. Presumably these are bespoke to the wheels? needless to say, I am after a new set. Thanks Quote Link to comment Share on other sites More sharing options...
Shunter8 Posted June 6, 2020 Share Posted June 6, 2020 Best place I found was eBay, search for spigot rings. If you have a micrometer measure the inside diameter of your wheel centre and then what size you need to reduce down to for your car. 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 6, 2020 Share Posted June 6, 2020 What he has said ^^^^ You will require both sizes to order the correct sized spigots. However if you don't have accurate measuring tools, just remove one of your old spigot rings and the sizes should be stamped/embossed on one of the faces. 1 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted June 6, 2020 Share Posted June 6, 2020 What I bought for my Varrstoen 73.1mm to 66.1mm https://www.ebay.co.uk/itm/162546259099 1 Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted June 8, 2020 Author Share Posted June 8, 2020 Brilliant; thank you all Quote Link to comment Share on other sites More sharing options...
