New Z confirmed by Nissan
Adrian@TORQEN
We will likely NOT see the full pallet of exterior colours imo just a fully loaded (non Nismo) model shown which will prob be the best way to spec one. Eager to see the blue. If its a Lexus Fractal Blue or Porsche Miami Blue then I would take that over the Pearl Yellow.
Nissan has released the press kit on their website. There's a lot of information to sink our teeth into!
usa.nissannews.com
2023 Nissan Z Press Kit
usa.nissannews.com
Introducing the 2023 Nissan Z. Developed by a passionate team of designers and engineers, the all-new Z represents an approachable sports car for the modern age – with an unmatched 50-plus year heritage and global fan base.
“Z is the pure expression of thrill. It is Nissan’s passion wrapped up on four wheels,” said Ashwani Gupta, representative executive officer and chief operating officer, Nissan Motor Co., Ltd. “The new Z retains its authenticity as a pure sports car to keep you connected to the road while bringing in the latest modern technologies to make sure the car can help keep you connected to your life."
The all-new, seventh-generation 2023 Z, which drops its numerical prefix in the U.S. for the first time, is scheduled to go on sale at Nissan dealers nationwide in spring 2022.
The new Z: An exhilarating, dynamic performer
The original 240Z was built to bring the joy and excitement of sports car ownership to as many people as possible – a car built for enthusiasts, by enthusiasts. That spirit and heritage continues today with the launch of the latest reincarnation of Z.
The 2023 Z’s 3.0-liter V6 twin turbo engine adds a significant bump in power output over the previous generation 370Z. The engine is rated at 400 horsepower at 6,400 rpm and 350 lb-ft of torque starting from 1,600 to 5,600 rpm. With an increase of 68 horsepower and a 30 percent increase in torque, the engine is designed to deliver a sharp, yet smooth response to the driver’s input, along with an estimated 15 percent improvement in 0 to 60 mph acceleration.
“Simply put, our goal is to make this the best Z yet, period. With each generation, we raise the bar, pushing the limits of Z and continuing to tap into the human instinct for that next thrilling journey,” said Hiroshi Tamura, chief product specialist of the new Z. “More than just powerful and agile, the 2023 Z is designed to be one with the driver for all kinds of on-road adventures.”
To achieve the marked increase in horsepower and torque, and to deliver sharp response, small-diameter turbochargers were adopted, as well as a turbo speed sensor to ensure the capabilities of the turbos are fully utilized (max spooling speed). The twin turbos balance power output and response time, while the use of an electronic variable valve timing (e-VVT) intake valve system ensures optimum response, adjusting the intake valve timing on-the-fly to achieve excellent response and fuel efficiency in a variety of driving scenes.
One of the defining traits of Z has always been its bond between the car and the driver – a physical and visceral connection, nonmatter the road ahead. That human-machine bond dominates the new Z, especially in the presence of the standard, 6-speed manual transmission.
The 6-speed close-ratio manual transmission includes an EXEDY® high-performance clutch. As a physical touch point between driver and Z, the shifter glides to the next gear, almost instinctively, with minimal effort.
In a first for a rear-wheel drive Nissan vehicle, Z Performance models equipped with a manual transmission include an advanced launch assist control system that helps deliver smooth acceleration from a stopped position. All automatic transmission-equipped models feature the launch control system. Manual transmission-equipped models also feature a carbon-fiber composite drive shaft, with SynchroRev Match® added to 6MT Performance models.
An advanced, quick-response 9-speed automatic transmission is also available. The new 9-speed automatic offers a direct and quick response feeling and quick acceleration, thanks to its wide gear ratio spread and standard launch control system. Its satisfying engagement keeps the thrill of Z power and performance in sync with the driver. Aluminum paddle shifters are standard on all 9AT-equipped models, with unique paddle shifters, the same design as found on GT-R, on Performance models.
The engineering team tuned the chassis, cooling, suspension and steering to ensure the driver always feels connected with the car. Getting behind the wheel, the Z feels new and modern, yet still familiar.
When it comes to delivering predictable, responsive handling, the engineering team took a multi-prong approach, especially for high-speed driving and cornering. Enhanced body rigidity, an electronic power steering with rack assist and a strong mechanical feel, and wider front tires (on both Sport and Performance grades) help increase maximum cornering G up to 13 percent.
Both front and rear dampers use a new monotube shock absorber design with a larger diameter than the outgoing 370Z, resulting in an approximately 20 percent reduction in dampening force to help minimize impact shock over uneven surfaces, enhance road-following performance and improve handling stability. The front double-wishbone aluminum suspension features new geometry, including increased caster angle, improving straight line stability. A two-point front strut tower brace is standard. The rear independent multi-link aluminum suspension has also been reconfigured with new settings.
Two drive modes are offered on automatic transmission models, standard and sport. Standard mode is best suited for commuting and long highway drives for a pleasant drive. Sport mode unlocks the Z’s performance potential, offering faster acceleration control, a sports-mode steering algorithm, active sound enhancement and sports-mode vehicle dynamic control setting best matched to take on a spirited run through a winding road. All Z Performance grade models (automatic and manual) utilize a mechanical clutch-type limited-slip differential.
Responsive braking is provided by 4-wheel ventilated disc brakes. Larger sport brakes with red-painted calipers are standard on Performance grade models. The Z Sport grade rides on dark-painted 18-inch aluminum-alloy wheels with Yokohama ADVAN Sport high performance tires, while Z Performance grades features 19-inch RAYS® super lightweight forged aluminum-alloy mounted with Bridgestone Potenza® S007 high performance tires.
2023 Z design – past meets future
The 2023 Z boasts a fresh, sleek exterior design with an appearance that communicates respect to its lineage. Its long hood and short deck are fundamentally Z, with a fresh look that is “love at first sight.” The design theme for the exterior and interior of the new Z was “tradition with modern technology.”
"Inspired by the voices of thousands of Z owners and Z lovers, and ignited by internal conversations around the six generations of Z that have come before, we found ourselves gravitating towards the sketches that touched the high points of certain decades while remaining true to our vision of the future," said Alfonso Albaisa, global head of design at Nissan. “Ultimately, we created a Z that travels between the decades while being completely modern."
For the exterior, the new Z takes on a traditional rear-wheel-drive sports car design, with a long hood, lower rear stance and a silhouette that pays homage to the first-generation Z. The designers utilized the latest technologies to streamline the design, and incorporated LED lighting to give dimension without unnecessary elements. The LED headlights have two half-circles that take their inspiration from the Japan market-only 240ZG of the 1970s, which fit naturally with the new Z’s identity.
The link to the original Z is most striking when viewing the 2023 Z from the side. The roofline flows from the nose to the squared-off rear to create a distinctive first-generation Z profile, whose rear edge was slightly lower than the front fender height giving the Z its unique posture.
The signature transition from the rear quarter glass to the low-slung position of the rear tail adds to the effect. Door handles are a flush-mounted design and the rear hatch design is ultra-thin, yet with increased rigidity over the previous 370Z design. In the rear, the blister fenders smoothly direct flow air past the horizontal rear panel. The rear combination lamps incorporate modern technology into the design reminiscent of the Z32 (1990-1996) 300ZX, including new 3D signature LED taillights.
The Z Performance grade features a rear spoiler that creates positive pressure where the rear hatch and spoiler meet, mitigating rear lift. The front spoiler takes advantage of knowledge gained through Nissan GT-R development to utilize negative pressure zones.
The new 2023 Z is available in three monotone exterior colors – Black Diamond Metallic, Gun Metallic and Rosewood Metallic. The new Z is also offered with a two-tone exterior, including six colors combined with a Super Black roof: Brilliant Silver, Boulder Gray, new Seiran Blue, new Ikazuchi Yellow, Passion Red TriCoat and Everest White Pearl TriCoat.
Z interior: modern tech with a vintage touch
Designed to fit the driver and passenger like a glove, the 2023 Z cabin seamlessly blends modern technology with vintage Z touches. The center stack takes inspiration from other generations before it, with three analog pod gauges on the instrument panel, 8.0-inch touchscreen audio display in the center and climate control switches near the shifter.
The interior design team also sought advice from professional motorsports legends, such as Nissan Super GT500 driver Tsugio Matsuda, to give the Z an ideal sports car cabin for all driving scenes. This can be seen in the instrumentation, with all vital information found in the 12.3-inch customizable digital meter display and arranged to help the driver grasp it at a glance, such as the redline shift point at the 12 o’clock position.
The 12.3-inch TFT meter display is all-new with three display modes to suit driver preference. “Normal” mode offers a sporty feel with the center area for navigation, audio and vehicle information. “Enhanced” mode pushes the tachometer and speedometer to the edges of the display, giving more space in the center for a larger navigation map and information to be displayed. “Sport” mode prioritizes the tachometer in the center with shift-up light at the top for shift information in the driver’s field of view. The Sport mode also allows for a boost gauge or G meter to be displayed.
The new Z’s center stack uses a three-zone approach, placing three analog pod gauges on the instrument panel (boost, turbo speed, volt) within the driver’s eyesight. Both the manual and automatic shift levers are new, each of them custom-engineered for optimized grip and comfort.
The new, deep-dish steering wheel offers the driver quick access controls without losing its vintage aesthetic.
The design of the seats utilizes know-how from the GT-R’s development to enhance both hold and fit. An expanded use of suede on the seatback suppresses initial lateral shake on the body, creating more comfortable drives, as well as reducing body movement when the vehicle is aggressively cornering.
The 2023 Z Sport grade offers black woven cloth seats with an 8-way manual driver’s seat and 4-way manual passenger seat. The Z Performance grade adds leather-appointed seating surfaces, 4-way power driver’s seat with manual lifter, lumbar and thigh support, 4-way power passenger seat and heated seats.
A full range of convenience features are offered as standard equipment, including Nissan Intelligent Key™ with Push Button Start, Intelligent Cruise Control, Automatic Temperature Control, auto-dimming rearview mirror, RearView Monitor, two 12-volt power points, two USB points (Type-A and Type-C), and front and rear sonar sensors. The 8.0-inch display audio touchscreen with six speakers includes Apple CarPlay® and Android Auto™, Bluetooth® Hands-free Phone System, Streaming Audio via Bluetooth®, SiriusXM® Radio, Hands-free Text Messaging Assistant and Siri® Eyes Free.
The Z Performance grade includes a 9.0-inch touchscreen with navigation and NissanConnect® Services with Wi-Fi hotspot. Also included is an 8-speaker Bose® Audio system with Active Noise Cancellation and Active Sound Enhancement.
Three interior color environments are available – Black, Red and Blue. The special Z Proto Spec edition features yellow accents throughout the cabin, including stitching on the instrument panel. The seats feature layered seat material to create depth and a gradation effect.
Two models, one limited edition
For the United States market, the 2023 Nissan Z will be offered in Sport and Performance grades, each with a choice of a 6-speed manual or new 9-speed automatic transmission.
All models include a range of standard driver assistance and safety technologies, including Automatic Emergency Braking with Pedestrian Detection, Blind Spot Warning, Lane Departure Warning, Rear Cross Traffic Alert, High Beam Assist and Intelligent Forward Collision Warning.
In addition to the wide range of standard comfort, convenience and connectivity features on the Sport grade, the Performance grade adds the 8-speaker Bose® Audio System, 9.0-inch touchscreen with navigation, NissanConnect® Services with Wi-Fi hotspot, mechanical Limited Slip Differential, 19-inch RAYS® super lightweight forged aluminum-alloy mounted with Bridgestone Potenza® S007 high performance tires, Nissan Sport Brakes, heated side mirrors, aluminum sport pedals, dual exhaust with Performance grade muffler and heated, leather-appointed power seats.
One special edition is available, celebrating the distinctive Z Proto introduced in 2020 – called the Proto Spec. Limited to just 240 units in the U.S., the Proto Spec model includes yellow-colored brake calipers with Z logo, bronze-colored 19-inch RAYS aluminum-alloy wheels, exclusive shift lever knob (6MT only), exclusive Proto Spec leather-appointed seats with yellow accents, exclusive Proto Spec suede + cloth door trim with yellow stitching and special Proto Spec interior stitching.
“The Z is more than a sports car you drive, it is an extension of the driver that moves and responds to the driver’s intentions,” added Gupta. “Whether on an unexplored winding road or your daily commute, the Z brings a smile and awakens the senses.
1 hour ago, DoogyRev said:
For $40K and 400BHP its certainly bang for your buck, Toyota will need to rethink their pricing. The Z looks better in Blue for sure, but I still think its kinda funny looking :shrug:
Thats around £28,750. Although no official pricing yet. Only 2 trims Sport and Performance. Which makes me think previous leaked info will be changed.
When you add in import duty and VAT its nearing £40,000 including shipping and IVA. Thats puts it right on what was predicted a year ago. I have a feeling cars will ve marked up at dealers and used market will be strong in accordance to the current trend.
Spring 2022 release is on the money.
No price but Nissan USA Instagram are rating the sport trim at $40,000 and Performance higher at around $45,000. Still unconfirmed and can change.
Sport Exhaust and Wheels are part of the Performance trim
Edited by GranTurismoEra
They did release the color options. Both interior and exterior.
Exterior:
Monotone: Black Diamond Metallic, Gun Metallic and Rosewood Metallic.
Two-tone: Brilliant Silver, Boulder Gray, new Seiran Blue, new Ikazuchi Yellow, Passion Red TriCoat and Everest White Pearl TriCoat. All with a Super Black roof.
Interior: Black, Red and Blue
What’s the betting you can’t have the sport steering mode on in comfort mode, and vice versa? And you can guarantee that one mode or the other will feel awful too.
That’s a nice blue it’s offered in, best colour yet.
I really want to like the styling.. but I just dont.
The blue imo looks the better of the 2 in my opinion and I think the interior, particularly the seats look great.
The engine and drivetrain specs should make it a blast. Probably with the turbo setup we are going to see a lot of high bhp tuned cars coming along in the future.
Oh my god I'm so excited for this, I would be hoping to buy one of these to add to the 350Z Nismo (helps being out in Japan).
Will depend how much they charge in Japan, $40,000 is a very good price for the base model, hopefully that means it will be 4,000,000JPY.
4 million Yen seems cheaper than a 370z Nismo with very low miles
2 hours ago, The G Man said:
If it ever did come to the U.K. (moanty fck brexit :p), I’d add one of them to my drive B)
I think a lot people could get one but Import Duty and VAT is very off putting. By the time it comes its still cheaper than a 2 liter Supra. Well kinda. The Sport Spec anyway.
Mechanical
Engine Sport Performance
Name VR30DDTT 3.0L V6 Twin Turbo
Cam design DOHC
Orientation Longitudinal
Cylinders / configuration V6
Block / head composition Aluminum/aluminum
Displacement (liters) 3.0 / 3042
Horsepower 400 @ 6,400 rpm
Torque (lb-ft) 350 @ 1,600 - 5,600 rpm
Bore & stroke (mm) 86.0 x 86.0
Compression ratio 10.3
Maximum engine speed 6,800 rpm
Induction system Twin turbochargers
Valvetrain 4 valves per cylinder; Continuously Variable Valve Timing Control System (CVTCS)
Fuel delivery system Direct Injection Gasoline
Engine oil cooler type Engine coolant
Cooling fan type Electric
Recommended fuel Premium unleaded
Emissions system Closed loop feedback system w/ 4 catalysts
Emissions certification level 50 state: LEV2-LEV (CARB), Tier2-Bin5 (Fed)
Exhaust Dual w/ chrome finishers Dual w/sport grade muffler
Transmission and Drive System Sport Performance
Drive configuration Mid-mounted front-engine / rear-wheel drive
Transmission type
6-speed close-ratio manual w/EXEDY high-performance clutch
S
O
S
S
O
S
S
9-speed auto w/drive mode switch, shift by wire
Paddle shifters (9AT)
Unique paddle shifters (9AT)
Launch control
Gear ratio
1st
2nd
3rd
4th
5th
6th
7th
8th
9th
Reverse
MT
3.795
2.325
1.625
1.272
1.000
0.795
3.446
AT
5.425
3.263
2.250
1.649
1.221
1.000
0.862
0.713
0.597
4.799
Final drive ratio 3.538 3.133
Drive shaft Carbon fiber composite (6MT only)
Downshift Rev Matching S (9AT)
SynchroRev Match® - S (6MT)
Mechanical clutch-type limited-slip differential - S
Limited Traction mode/slip function S (9AT) -
Hill Start Assist S S
Transmission coolers 9AT oil warmer and air-cooled cooler
Brakes Sport Performance
Front – vented disc S -
Rotor size diameter and thickness -
(in.) 12.6 x 1.10
Rear – vented disc
(in.) 12.1 x 0.63
S -
Front – Vented disc
(in.) 14.0 x 1.26
- S
Rear – vented disc
(in.) 13.8 x 0.79
- S
Caliper type / material Fixed 2-piston front, single piston rear / cast iron Floating 4-piston front, 2-piston rear / aluminum
Red caliper color - S
Yellow caliper color - O
Brake control Power-assisted (vacuum)
Anti-lock Braking System
Number of wheels/channels/sensors
S
4/4/4
Brake Assist S
Electronic Brake force Distribution S
Parking brake – mechanical, pull-type S
Steering Sport Performance
Type Electric power steering (electric rack)
Vehicle speed variable assist S
Steering wheel 3-spoke leather-wrapped w/ air bag, manual tilt
Premium leather steering wheel - S
Steering wheel controls – illuminated Cruise control, audio, Bluetooth® Hands-Free Phone
Manual tilt and telescopic steering column S
Suspension
Front
Subframe construction
Stabilizer bar
Shock absorbers
Double-wishbone aluminum suspension
High vacuum diecast aluminum alloy
S
Monotube
Rear
Stabilizer bar
Shock absorbers
Independent multi-link aluminum suspension
Steel
S
Monotube
3-point front strut tower brace S
Sport-tuned suspension - S
Body / Chassis
Type Unibody
Materials (primary) Corrosion-resistant high-strength steel
Hood, doors, rear hatch Aluminum
Exterior
Wheels & Tires Sport Performance
Wheels
Dark-painted aluminum-alloy
F: 18x9 inches R: 18x9 inches
S -
F: 19x9.5 inches R: 19x10 inches
- S
Bronze-colored aluminum-alloy wheels
- O
Tires
F: P245/45R18, R: P245/45R18
S -
F: P255/40R19, R: P275/35R19
- S
Tire repair kit S
Tire Pressure Monitoring System, direct sensor type S
Lights Sport Performance
Headlights LED low and high beam
LED daytime running lamps
S
S
Automatic on/off S
Intelligent Auto Headlights S
LED taillights S
Side mirror LED turn signal indicators S
High Beam Assist S
Exterior Features Sport Performance
Body-colored door handles S
Black front grille S
Body-colored front and rear bumpers S
Manual-folding body-colored outside mirrors with turn signals S
Heated outside mirrors - S
Manual opening and closing hatch S
Front chin spoiler - S
Rear spoiler - S
Side sill spoiler S
Interior
Seating Sport Performance
Capacity 2-passenger
Seat Materials Black woven cloth Synthetic suede inserts S
S
Leather-appointed - S
Unique seat cushion and side bolster design - S
Exclusive Proto Spec leather-appointed seats with yellow accents - O
Exclusive Proto Spec suede + cloth door trim w/yellow stitching - O
Proto Spec interior badging - O
Seat Type Sport bucket S
Height-adjustable head restraints S
Heated - S
Driver Seat 8-way manual S -
4-way power w/manual lifter, lumbar and thigh support - S
Passenger Seat 4-way manual S -
4-way power - S
Suede-appointed door trim - S
Audio/Navigation Sport Performance
Nissan audio system with 6 speakers S -
8.0-inch touchscreen S -
Bose® audio with 8 speakers, Active Noise Cancellation, Active Sound Enhancement - S
9.0-inch touchscreen display with navigation - S
Apple CarPlay® S
Android Auto™ S
Streaming Audio via Bluetooth® S
Bluetooth® Hands-free Phone System S
Siri® Eyes Free S
Hands-free Text Messaging Assistant S
SiriusXM® Radio (SiriusXM® subscription required, sold separately) S
Voice Recognition S
NissanConnect® with WiFi hotspot - S
NissanConnect® Services - S
Instrumentation Sport Performance
Fully digital TFT meter display
Speedometer, Tachometer
Coolant temperature
Fuel level
LCD dual trip odometer
S
Instrument panel-mounted 3-bay gauge cluster (turbocharger boost, turbocharger turbine speed, voltmeter) S
Indicators
Clock
Low Tire Pressure
Programmable M/T shift up timing indicator (light)
Cruise Control
VDC off
S
S
When equipped with 6MT
S
S
Drive computer + G-meter S
Convenience Features Sport Performance
Intelligent Cruise Control S
Power windows –one-touch up/down S
Power door locks with auto locking feature S
Nissan Intelligent Key® with Push Button Ignition S
Auto-dimming inside rearview mirror S
RearView Monitor S
2 12-volt power points S
Knee pad on center console tunnel S
HomeLink® Universal Transceiver - S
Aluminum trimmed sport pedals - S
Locking glove compartment S
Glove compartment dampening - S
Rear window defroster with timer S
Front center console with armrest, storage bin S
Cupholders (2) /bottle holders (2) S
Front map lights (2) S
Cargo area lamp S
USB charging ports (1 Type A, 1 Type C) S
Dual sunvisors w/ illuminated vanity mirrors S
Front and rear parking sensors S
Automatic Temperature Control S
Safety and Security
Passenger Restraint Systems
Nissan Advanced Air Bag System Driver and front passenger air bags with dual-stage inflation, seat belt sensors and occupant classification sensor
Driver and front passenger seat-mounted side-impact supplemental air bags S
Roof-mounted curtain side-impact supplemental air bags S
Outboard seat belts, front 3-point (ALR/ELR for pass., ELR for driver)
Seatbelts with pre-tensioners and load limiters S
Top tether anchor (passenger seat) S
Safety and Security Features
Zone Body Construction with front and rear crumple zones
Energy-absorbing steering column
Slide away brake pedal
Break away rear engine mount
Hood buckling creases and safety stops
Body side reinforcements
Aluminum side-door guard beams
Power window lockout button
Vehicle Dynamic Control
Traction Control System
Nissan Vehicle Immobilizer System
Vehicle Security System
S
Automatic Emergency Braking with Pedestrian Detection S
Intelligent Forward Collision Warning S
Blind Spot Warning S
Lane Departure Warning S
Rear Cross Traffic Alert S
Dimensions
Exterior (inches) Sport Performance
Wheelbase 100.4
Overall length 172.4
Overall width 72.6
Overall height 51.8
Ground clearance 4.8
Track Fron t
Rear
61.6
62.8
61.2
61.6
Interior (inches)
Head room 38.2
Leg room 42.9
Hip room 54.6
Shoulder room 54.2
Options Spor  t Performance
Proto Spec: Yellow-colored brake calipers, bronze-colored aluminum-alloy wheels, exclusive shift lever knob (MT only), exclusive Proto Spec leather-appointed seats with yellow accents, exclusive Proto Spec suede + cloth door trim with yellow stitching, special Proto Spec interior stitching
