W8BGS Posted April 29, 2020 Share Posted April 29, 2020 As above, don't really want to buy from Nissan. Ideally I need both. Mine have carbon covers and they were the flimsy type and now part of the lacquer is coming off, I think if I try and remove the cover the trim will snap. Quote Link to comment Share on other sites More sharing options...
Jack94 Posted April 29, 2020 Share Posted April 29, 2020 For any used OEM parts probably worth firing @ZMANALEX a PM. 1 Quote Link to comment Share on other sites More sharing options...
Umster Posted April 29, 2020 Share Posted April 29, 2020 Good write up on a clear coat repair here. Else Google "370z B pillar removal" and there's a few how to guides on removing the pillars without snapping the 3 clips. Provided you've got patience and a trim removal tool (flathead screwdriver and some tape/sponge) it's a DIY job and you can fudge a repair on the clips. Supposedly A and B pillars need to be removed to change the windscreen. . . 1 Quote Link to comment Share on other sites More sharing options...
W8BGS Posted April 29, 2020 Author Share Posted April 29, 2020 5 minutes ago, Jack94 said: For any used OEM parts probably worth firing @ZMANALEX a PM. Thanks, did do a while back abmnd he didn't have any, but will try again Quote Link to comment Share on other sites More sharing options...
W8BGS Posted April 29, 2020 Author Share Posted April 29, 2020 5 minutes ago, Umster said: Good write up on a clear coat repair here. Else Google "370z B pillar removal" and there's a few how to guides on removing the pillars without snapping the 3 clips. Provided you've got patience and a trim removal tool (flathead screwdriver and some tape/sponge) it's a DIY job and you can fudge a repair on the clips. Supposedly A and B pillars need to be removed to change the windscreen. . . Thanks for this, I think mine are beyond repair as I don't think they are proper carbon fibre, more of a sticker. I can get the b-pillars off the car, but can't get the sticker off the trim. Maybe I'll give it a go, what's then worst that can happen Quote Link to comment Share on other sites More sharing options...
