TiN TiN Posted April 18, 2020 Share Posted April 18, 2020 The passenger window isn't working. It's not going up and down when opening/closing the door either. The window lock switch is not pressed. It doesn't open or close using the switch from either side. I've just changed the window motor, and it's still not working. I've opened the switch, and it doesn't seem to be in a good state, but would this stop the driver's side switch from working? What else could it be? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 18, 2020 Share Posted April 18, 2020 Bench test the motors off a direct 12volt supply. Perhaps they are both bad or perhaps the fault lies elsewhere. Quote Link to comment Share on other sites More sharing options...
TiN TiN Posted April 18, 2020 Author Share Posted April 18, 2020 38 minutes ago, ZMANALEX said: Bench test the motors off a direct 12volt supply. Perhaps they are both bad or perhaps the fault lies elsewhere. If you were to give someone a 10 second lesson on how to do this...... Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 19, 2020 Share Posted April 19, 2020 10 hours ago, TiN TiN said: If you were to give someone a 10 second lesson on how to do this...... Firstly, hook up your meter and check that the motors are getting a live feed. When you are there, run a 12v feed and ground to the motor. If the motor is good the motor will operate. Quote Link to comment Share on other sites More sharing options...
Ben–350Z Posted April 19, 2020 Share Posted April 19, 2020 On 18/04/2020 at 21:01, TiN TiN said: 've opened the switch, and it doesn't seem to be in a good state, but would this stop the driver's side switch from working? Definitely on mine the passenger window wouldn't work unless both switches were connected... 1 Quote Link to comment Share on other sites More sharing options...
TiN TiN Posted April 19, 2020 Author Share Posted April 19, 2020 1 hour ago, Ben–350Z said: Definitely on mine the passenger window wouldn't work unless both switches were connected... Thanks, that's helpful. I suspect it's the passenger side switch. Do you know where the best place to buy these is? Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted April 20, 2020 Share Posted April 20, 2020 11 hours ago, TiN TiN said: Thanks, that's helpful. I suspect it's the passenger side switch. Do you know where the best place to buy these is? he will probably have one if not ebay 2 Quote Link to comment Share on other sites More sharing options...
TiN TiN Posted April 20, 2020 Author Share Posted April 20, 2020 16 minutes ago, ShortPaul said: he will probably have one if not ebay 16 minutes ago, ShortPaul said: he will probably have one if not ebay @ZMANALEX See images below. Do you have these available? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 20, 2020 Share Posted April 20, 2020 Yes, in stock at the minute. Quote Link to comment Share on other sites More sharing options...
TiN TiN Posted April 20, 2020 Author Share Posted April 20, 2020 15 minutes ago, ZMANALEX said: Yes, in stock at the minute. What's the price? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 20, 2020 Share Posted April 20, 2020 I will send you over images of what I have tonight as there are 2 types with prices. 1 Quote Link to comment Share on other sites More sharing options...
Ben–350Z Posted April 20, 2020 Share Posted April 20, 2020 2 hours ago, ShortPaul said: he will probably have one if not ebay Beat me to it 1 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 20, 2020 Share Posted April 20, 2020 Are these the switches that you are after? Quote Link to comment Share on other sites More sharing options...
TiN TiN Posted April 20, 2020 Author Share Posted April 20, 2020 1 hour ago, ZMANALEX said: Are these the switches that you are after? 8 hours ago, ShortPaul said: he will probably have one if not ebay 6 hours ago, Ben–350Z said: Beat me to it @ZMANALEX Yeah, just the passenger side, and just the bit that says G on it. Is it working? How much do you want for it? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 20, 2020 Share Posted April 20, 2020 I am happy to just sell you the one switch, however, I only sell the complete switch and not just the printed circuit I am afraid. Fully working when removed. If you wish to purchase then just drop me a PM. Quote Link to comment Share on other sites More sharing options...
TiN TiN Posted April 21, 2020 Author Share Posted April 21, 2020 11 hours ago, ZMANALEX said: I am happy to just sell you the one switch, however, I only sell the complete switch and not just the printed circuit I am afraid. Fully working when removed. If you wish to purchase then just drop me a PM. Pm'd Quote Link to comment Share on other sites More sharing options...
