350z De running rich
Sam_Patmore
So I've been racking my brains over this and I have no other ideas on what to do next. Long story short, my Z had been laid up for a while and I decided to put her back on the road, sailed through the MOT all fine no issues etc. About a week later, she developed a misfire, so I replaced all the sparks and ignition packs, the car began running rich, loss of MPG. A couple of days later, I went over a horrible sleeping police man which destroyed my OEM Cats. had to drive home with the wrecked ones still on and, according to the mechanic, it was just a molten mess in them where it wasn't releasing any fumes. So I put my old decat pipes on. Still running rich, massive drop on the MPG, but no misfiring but has a rough idle, occasionally pops when I put my foot down.
Since then I have done the following:
Replaced the valve rockers as gaskets leaking
Installed plenum spacer
Cleaned all the throttle body
Clean all the plenum chamber
Cleaned the air intake
Replaced the MAF sensor
Done the pedal dance for ecu reset, throttle idle position etc
And still the bloody thing is running rich and I have no clue why. The car isn't displaying any eml lights or anything but I just can't work out whats with the rich fuel mix and drop in MPG and when I say a drop, I'm getting roughly 14mpg. I will, once everything is over with this pandemic be getting it tuned and putting high flow cats on which should help but other then that I can't think of what else it could bethat it is still causing it. Would appreciate any suggestions :)
I know that you say that there is no EML showing but are there any stored DTCs?
Faulty front O2 sensors spring to mind but that should throw an EML.
Could be numerous things but it is getting late and my brain is getting a bit tired. lol.
ps: Dirty/blocked air filter element perhaps.
No stored codes, and regards to and O2 sensor, that was one of my thoughts but yer, no eml. I'l give the air filter element a look, see whats its like, I have a Takeda short ram intake but never had a problem with that before and i've cleaned that all up
