Best brake discs?
Dan350ZGT
Hi there, I am in the same boat with replacing discs and pads. Though discs are only half-way through and I can feel light pulsating. Disc is also unevenly worn - tiny bit thicker by the hub and thinner at the edge. So, once skimmed they might be at a minimum. I already have OEM Brembo pads (previous owner pass them to me) so I am looking for a disc.
Don't want to go spending for pads, so I am looking at OEM Brembo Extra Line. Since this combo goes together as factory oem,
How would DBA T2 go together with OEM Brembo pads?
Not doing any trackdays, a spirited drive here or there only.
I suspect some people have had that combo, although I tend to worry more about spending decent money on the pads and just getting a standard set of discs. The consensus on the VX forum given they are all track guys is that pads is where the budget should go!
