evest Posted March 31, 2020 Share Posted March 31, 2020 Hi all, 2003 DE, I have a motordyne 5/16 plenum spacer but have lost (for good) one of the internal plastic spacers/washers. I've made do without it for a bit but not ideal to continue. I guess unlikely anybody has spares lying around but worth a try! Failing that, any full second hand plenum spacer kits on offer? Cheers! Quote Link to comment Share on other sites More sharing options...
reeceybeaney Posted April 1, 2020 Share Posted April 1, 2020 That's frustrating! I made plenum spacer kits for a while, although I'm out of the workshop for the foreseeable... if you get really stuck and I'm back at work, I'll turn one up for you 1 Quote Link to comment Share on other sites More sharing options...
evest Posted April 1, 2020 Author Share Posted April 1, 2020 8 minutes ago, reeceybeaney said: That's frustrating! I made plenum spacer kits for a while, although I'm out of the workshop for the foreseeable... if you get really stuck and I'm back at work, I'll turn one up for you Cheers pal, if nothing turns up I'll carry on without it (not that im driving anywhere anyway!) and perhaps contact you when life gets back to normal? Quote Link to comment Share on other sites More sharing options...
reeceybeaney Posted April 1, 2020 Share Posted April 1, 2020 48 minutes ago, evest said: Cheers pal, if nothing turns up I'll carry on without it (not that im driving anywhere anyway!) and perhaps contact you when life gets back to normal? Yeah no worries at all, just make sure you don't tighten the plenum down too much there as it won't be supported, under that position, and could crack if not careful! No worries 1 Quote Link to comment Share on other sites More sharing options...
evest Posted April 1, 2020 Author Share Posted April 1, 2020 3 hours ago, reeceybeaney said: Yeah no worries at all, just make sure you don't tighten the plenum down too much there as it won't be supported, under that position, and could crack if not careful! No worries Sage advice, see below! heard it ping as i unbolted it. Although i think my rubbing strut bar may have been responsible for this. Fleabay to the rescue! Quote Link to comment Share on other sites More sharing options...
evest Posted April 23, 2020 Author Share Posted April 23, 2020 Well, I sourced some new spacers from Horsham Developments (Cheers Jez). However... ...on removing the upper and lower plenum, and the intake manifold, guess what I found nestled in the 'V'.... its managed a couple of thousand miles under there! Quote Link to comment Share on other sites More sharing options...
zelda Posted April 24, 2020 Share Posted April 24, 2020 Wow. Quote Link to comment Share on other sites More sharing options...
