Keeping busy during furlough
Sam_Patmore
So, after finding out today that I'm being furloughed for a couple of months, I'm going to take the time to work on the 350.
I'm going to be putting in a plenum spacer and also replacing the rocker covers, with spark plug grommets etc.
Whilst I'm diving headlong into the engine bay, is there anything that I should be replacing at this stage in the engine, I've changed all the sparks and coil packs only last week.
Appreciate any ideas
Cheers
3 minutes ago, Shunter8 said:
Gearbox oil, diff oil, brake fluid, clutch fluid and coolant flush? Often overlooked fluids that also require a change every few years generally.
Recently finished purchasing everything i need to do a full service, found the diff oil and coolant cheapest on ebay (genuine) along with the Belts. Gearbox x 3 was cheapest on Torqen.
Everything else was Opie :)
