2003 UK Nissan 350Z
Ian
For sale is my unfinished Twin Turbo 350Z project car.
I have owned this car from 2006-2010 and then bought it back in 2016.
The car is a UK supplied 2003 car, and has full UK GT Spec. The car has 18" RAYS alloys with good tyres, Brembo brakes with good disks and pads, Black leather interior with no rips, tears or stains
To get the car finished, the following needs to be done
* Fit Turbo Kit and injectors
* Needs a Cat Back exhaust
* Needs a radiator
* Fuel Pump/Return System
* Centre dials/or fit boost/temp gauges like I planned.
* Top water hose
* Stereo if you like that kind of thing :)
Bad Points
As with all cars of this age, there are a few age related marks and there is a small door dent on the passenger door. The Front and Rear bumpers could do with a respray to be perfect and there is a Small rust bubble on both rear quarters as per pictures.
Modifcations fitted or supplied with the car
* APS Tall Boy Plenum
* Deatschwerks 600CC
* ARC Oil Catch can
* Berk Decat Pipes
* Modified Fuel Pump Holder
* Gloss black A-Pillar gauge pod
* Mishimoto Radiator Fans
* DC Sports Exhaust Manifolds
* Power Enterprise Twin Turbo Kit
   *PE1420 ball-bearing turbochargers (x2)
   *Custom turbo manifolds (x2)
   *Custom outlet pipes (x2)
   *High-capacity aluminum oil pan
   *Fuel pressure regulator
   *Air Impulse air intakes (x2)
   *Front-mount air-to-air intercooler
   *Inlet and compression pipe set
   *Oil lines
   *HKS SSQV
Kit is used, however there is NO play in the turbos.
Spare parts included in the sale
  • Keyless Entry Unit
  • Boot weight x2
  • Relay Cover
  • Control Unit 28550CD700
  • RHS Air Duct
  • RHS "Z Vent"
  • Passenger side interior door handle
  • Passenger side door arm rest
  • Footrest
  • Air con ECU module
  • Drivers side interior door handle
  • Oil filter housing
  • Rear cubby (broken door)
  • Fuel Rails
  • Air bag module
  • Horns
  • Drivers side knee pad
  • Upper driver side dashpanel
  • Passenger side window regulator
  • Brake fluid surround
  • Wiper arm mechanism
  • Strut Brace
  • Upper Plenum Chamber x 2
  • Drivers side kick panel
  • Boot foam
  • Front Crash Bar
  • Front bumper foam
  • Tool Kit
  • Rear boot corner plastics x2
  • Dashboard
  • Passenger side door card
  • Transmission mount
  • Relay fuse box cover
  • Petrol cap switch
  • Headlight washer switch
  • Clear side indicators
  • OEM radiator Cap
  • Bonnet release handle
  • ESP switch
  • radiator fans
  • Brake fluid resevoir tank
  • intake pipe
  • ABS pump
  • heater matrix
  • Right Rear Trim Panel Cover 84940CD000
  • left Rear Trim Panel Cover 84940CD000
  • PAS Oil cooler
  • Rear Brembo Calipers
Plus loads more interior pieces, hoses and rubber seals.
MOT has expired and car has started to be stripped ready to fit the TT kit.
Only selling due to family commitments and a 2 seater isn't practical anymore.
£7500
  • 4 months later...
