Passenger window auto (not) return
EvansJD2112
Hey.. looking for any guidance
I noticed that my passenger window had stopped auto-returning.
Tried the usual reset but without luck.
Finally get it booked into Nissan (under warranty) to look at it.
So far they've not identified the issue.
Other than trying the reset, they've tried replacing the window switches - no luck.
Unsure how long it's been broken - 99.9% of the time I have no passengers or need to open the door.
Any ideas I could pass onto Nissan?
I did have a Ecutek remap done last April; any potential that that could have caused it?
Cheers
Jon
To add a little detail my passenger window only auto returned after I modified the switch (allowing second position) which was detailed on this Forum back in the day. Drivers window was fine from day one.
Edited by MY NAME
Not sure we are on same topic:-)
I'm talking about when you open the door, it drops to allow you to clear the frame.
When you close the door, it should pop back up again.
Mine isn't popping back up - passenger door only.
Usually the reset procedure works - had to do many a time on previous Z's
