best way to sell my Z
andybp
So the question is do I sell my Z as is as a project car air ride suspension,Jenvey ITB's and Link ECU
or return the engine and ecu to factory-ish and sell the ITB's and Link ECU separately ?
I could even remove the air suspension and fit the standard springs what do you think ?
If you don't mind putting the effort in then personally I'd put the car completely back to stock, especially if you've still got all the bits.
The zed already has a narrow market, if you sell it as a project you're limiting that down even more.
Edited by Jack94
you're probably right but i think i'll advertise as is and see what response i get for now
i'm in no mad rush
i'm in no mad rush
There's almost certainly someone interested in it, in current state depending on the rest of the car too!
  • 1 month later...
7 hours ago, cs2000 said:
Haha that's a shame, I would be interested if you found the time of course! Wouldn't need your coilovers however as I have the BC BR's already, just the lines and everything else that goes with it.
I'll see how the virus goes as i can't sell the Z until it's over so what else am i going to do ?
So the age old problem what's it worth
This is how it will be sold
spec wise
18" alloys good tyres all round
BC Racing Coilovers with custom Air Ride setup
some of the suspension is poly bushed I have them all just haven't fitted them
true dual exhaust HKS copy
standard cat's fitted but also have high flow set that would go with it
high capacity ally sump
Link G4+ plugin ECU
also another engine with 25000 miles was fitted at 68000 miles now at 76000 miles so engine has about 33000 miles on it
Please note this is not an advert just trying to get an idea what I should put it up for when all this corona madness is over
