shawnsx Posted February 25, 2020 Share Posted February 25, 2020 Has anyone had any to replace this item recently? Mines appears to have a Slight crack on the passenger side causing a coolant leak. looking at the part it appears to only be 4 bolts and 2 gaskets to fit but I’m wondering if there is enough room to get it on and off without having to lift the engine thanks Quote Link to comment Share on other sites More sharing options...
Eddie_r32 Posted February 26, 2020 Share Posted February 26, 2020 Apparently the Americans do a thing called "pathfinder mod" which is replace that tube with one from a pathfinder, not sure if its a thing over here but there will be some how to guides knocking about which should tell you how to replace it Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 26, 2020 Share Posted February 26, 2020 8 minutes ago, Eddie_r32 said: Apparently the Americans do a thing called "pathfinder mod" which is replace that tube with one from a pathfinder, not sure if its a thing over here but there will be some how to guides knocking about which should tell you how to replace it I did the Pathfinder mod to my 350 track car around 12 years ago, easy to install, however the parts are not cheap. I have only sold a handful of these. I now sell/install the HR option for the DE which works well for FI and track cars. Quote Link to comment Share on other sites More sharing options...
Ian Posted February 26, 2020 Share Posted February 26, 2020 It can be removed with the engine in situ but be prepared for some bloody hands 1 hour ago, ZMANALEX said: I did the Pathfinder mod to my 350 track car around 12 years ago, easy to install, however the parts are not cheap. I have only sold a handful of these. I now sell/install the HR option for the DE which works well for FI and track cars. is the HR version better than the pathfinder mod? I've heard bad things about the pathfinder mod in the US Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 26, 2020 Share Posted February 26, 2020 6 minutes ago, Ian said: It can be removed with the engine in situ but be prepared for some bloody hands is the HR version better than the pathfinder mod? I've heard bad things about the pathfinder mod in the US The Pathfinder mod worked well for me and helped with keeping the coolant temps down on track. I wanted to experiment with the HR mod and this was fitted when the engine was out for other stuff, and that also worked well. What one is better would be hard to tell, however I think that my temps came down a further few degrees with the HR mod. Remember that my 350 is now close to 800 bhp with similar torque and generates extreme heat so every 1 degree is a prisoner. The stock rear pipe is all that you require for a sub 400 bhp 350. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 26, 2020 Share Posted February 26, 2020 Easy to replace insitu, however as Ian has said, not much room. Removing the plenum makes this job so much easier, with no requirement for a blood transfusion during/after. Quote Link to comment Share on other sites More sharing options...
shawnsx Posted February 26, 2020 Author Share Posted February 26, 2020 Cheers lads, will hopefully get it sorted at the weekend Quote Link to comment Share on other sites More sharing options...
