Trick to get plastic cowl back on
zelda
Hi all,
Whilst fitting RJM clutch pedal I had to remove the steering wheel cowl. After 3 tries I can't get the upper and lower halves to clip back back flush on both sides around the stalks.
Any tips, or just try and try again..?
05, DE.
45 minutes ago, davey_83 said:
My tips would be to remove completely and mock fit off the column, check there's no obstruction.
Nice work on the new clutch pedal!!
Not a bad shout. Will give that a go, thanks.
Tbh, after the pain of doing the pedal I'd not got the strength left in my fingers to have another go..
