gazza_606 Posted January 29, 2020 Share Posted January 29, 2020 Hi, hoping someone may be able to help me. I am after a bearing for the rear extension element of the transmission for a 2007 transmission. I have attached an image to show the location of the bearing to help with the search. There are no part numbers on the bearing, Nissan Uk cannot seem to source/know what one it is. I am wondering if this is just part of the assembly and i would need to buy the whole extension unit. Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 29, 2020 Share Posted January 29, 2020 All parts are in stock. I will get back to you tomorrow with more detail once back in the shop. Quote Link to comment Share on other sites More sharing options...
gazza_606 Posted January 30, 2020 Author Share Posted January 30, 2020 Hi ZMANALEX, that would be great if you are able to provide a price for that bearing. Thanks Gary Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 30, 2020 Share Posted January 30, 2020 Gary, You do not say if your car is an HR or a DE, however for pricing, the values are similar. There are 3 x bearings in the end casing and I am unsure which one you require. There are also numerous bushings and an oil seal that you may require. The bearings are priced at £50.94, £26.08, and £26.08 respectively and all are showing in stock. A complete new rear casing is £700.05 and is a 4-6 week order from japan. However, I have a very low mileage preowned (23,000 miles) rear casing in stock complete with good bearings, bushings and seals. This is the way that I would go as the bearings are very tricky to remove and install even with specialist tools. I can let you have this for £100.00. If you wish to proceed with your order then just drop me a PM.. Alex. Quote Link to comment Share on other sites More sharing options...
gazza_606 Posted January 31, 2020 Author Share Posted January 31, 2020 thanks for the reply, the bearing i need is shown in the picture below, it is for the main shaft bearing. I have circled the oil seal of where the bearing is located. The issue have is that i do not have the vehicle, its just the gearbox and i cannot get much from it apart from knowing it is a 2007-2008 version. I tried to send an attachment in a private message but had no luck hence rplying on here Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 31, 2020 Share Posted January 31, 2020 The part that you refer to is more of a bushing and is part of the casing and not a serviceable item I am afraid. As said before, I have a very low mileage preowned (23,000 miles) rear casing in stock complete with good bearings, bushings and seals. This is the way that I would go as the bearings/bushings are very tricky to remove and install even with specialist tools. I can let you have this for £100.00. If you wish to proceed with your order then just drop me a PM.. Alex. Quote Link to comment Share on other sites More sharing options...
gazza_606 Posted January 31, 2020 Author Share Posted January 31, 2020 ok thanks, i thought that would be the case. let me hav a think about the route forward i want to take and i will PM you if i want to proceed. Thanks Quote Link to comment Share on other sites More sharing options...
