retro_al Posted January 26, 2020 Share Posted January 26, 2020 (edited) 2004 Nissan 350z DE (UK) 12 months MOT Resprayed in ford frozen white about 3 years ago( originally was silver ) 110K Miles Pioneer head unit with rear camera ( camera don’t come on when in reverse, you just switch it on when you want so you can drive with it on ) Bonnet vented by nick wiley Import rear bumper Full custom stainless Exhaust system including Stillen Y pipe + sports cats Plenum spacer A/C deleted Stillen Larger Capacity Sump ( holds extra 1 ltr ) Large cone type air filter with cold feed Remapped at RS Tuning Leeds ( 289 bhp) New stoptech discs and Ferodo DS2500 pads ( last year ) Fully Polybushed New banana arms with superpro bush kit ( last year ) Adjustable Camber arms front and rear Adjustable Traction links Hel Braided brake pipes Goodridge Braided Clutch Line ( new slave cylinder fitted at the same time ) Dot 5.1 Brake fluid Oil catch can Greddy Organic clutch and single lightweight flywheel ( does chatter at low speed ) 30mm Lowering springs 19” DOTZ Hanzo wheels (just been refurbed satin black and ceramic coated) 255 35 19 tyres 25mm spacers in the rear, 5mm spacer on the front Tarmac Sport front lip Tarmac Sport side steps ( drivers side has a split ) Nismo Rear spoiler Ultra Racing W brace Nissan Service History upto 81021 miles Oil serviced by myself twice a year with Titian pro s oil Fresh gearbox and diff oil New spark plugs 109k miles Has had all new wheel bearings fitted ( didn’t need them im just to ocd ) 108041 miles Rear shafts stripped and serviced 107522 miles I’ve had this car about 3 years mostly used in the summer with a couple of track days,rest of the time its been in the garage, I do about 2k to 3k miles a year Engine and gearbox and clutch all in perfect order, no oil burning or crunching gears Suspension has been set up for fast road/ track use so there has been camber dialed into the front, so you might want to get it redone to factory settings if your using everyday Its also quite low so you do need to be careful on very bumpy pothole type roads Last two owners were enthusiasts Piles of receipts The EML does come on because of the sports cats, I have a code reader that I use to remove the light before It goes in for a MOT, so you will need to do this for next MOT unless you have a friendly MOT guy Might be worth trying to fit the sensor extenders I caught the front bumper coming out of my garage so there are some hairline type marks on the drivers side Small bubble on passenger rear arch Some holes in the rear strut bar plastics due to adjusters for the previous coilovers ( see pics ) Please come and view the car as it is 16 years old, you can test drive it if you have insurance Located west Yorkshire BD21 Video of the car on track,i never drove it like I stole it just nice and steady https://www.youtube.com/watch?v=tL1X-yrP6KY £4700 ovno 07779455919 Edited June 28, 2020 by retro_al Quote Link to comment Share on other sites More sharing options...
