350z Air Bag Clock Spring : RevUp DE ('06) Part Number
Rajtastic
Hi guys,
Wondering if anyone has changed their clock spring to try and fix the air bag light issue (fairly sure it's this as my 'volume up' and 'seek up' buttons have died on my wheel).
Torqen say the part number I should use is "25567-ET025". However, when I call Glynn Hopkins they haven't heard of it and ask say they'll buy in "B5567-CF42E".
Does anyone know the difference/which is the right one?
Here is my VIN if it helps : JN1GAAZ33U0302132
('06 RevUp DE)
Thanks,
Roshan
Edited by Rajtastic
I had mine replaced a couple years back by an independent garage.
They said alot of people buy the part and mess about turning it before fitting which can bigger them up.
I've no clue what they were on about but thought I'd just relay the story in case there was any truth behind it and "twisting" before fitting was hazardous.
This is true because they don't spin infinitely, they have a ribbon cable inside for the airbag, horn etc. If you don't install it centrally (i.e. 360 degrees out) the cable will snap when you turn the wheel full lock.
