corroded 370z gearbox pipes
gingerslippers
Hi there,
Wondered if someone could help!  I just put my 12 plate 370 auto in for service and asked them to check the car over as seen some marks on the drive and thought it may be the 370.  They have confirmed that 2 pipes have corroded hence the leak.  They have contacted Nissan to obtain the pipes but apparently Nissan have said that only 1 is available and the other is no longer produced!  I wondered if anyone had encountered such a problem or knew about where to source the parts and if an easy in house repair?
Cheers
I experienced the same issue a few months back for a customer/forum member, however after a bit of digging I came up with different part numbers and was able to source the pipes.
They are showing in stock at the minute so supply should not be a problem.
If you wish to order then please PM me your registration number and shipping details and I will get this sorted for you.
