Helpmeee Posted December 15, 2019 Share Posted December 15, 2019 Got a Nissan 350z I change the air intake and the car shut off 30 second after running it so I put the oem air intake and car doesn’t start now it crank there’s no check engine light the fans kick in and the security solid red light it’s on I need help what can it be ? Quote Link to comment Share on other sites More sharing options...
cs2000 Posted December 16, 2019 Share Posted December 16, 2019 (edited) Solid red security light means NATS (immobiliser system) doesn't recognise your key. Do the fans come on straight away when you turn the key? This is Nissans way of telling you theirs a major issue, usually ECU related. Check the MAF sensor is installed, connected electrically and not damaged too. Edited December 16, 2019 by cs2000 Quote Link to comment Share on other sites More sharing options...
