350z fault code
formatzero
Fault code PO174 came up on the car,had a mechanic friend plug a reader in and it came up with that code Lean bank 2.This came up as a stored code rather than a current fault and it reset ok.Had a look online to see cause and there was quite a list of possibilities .Whats the best way to narrow down these possibilities should it happen again ,cheers
Was it Bank 2 Sensor 1 or Sensor 2?
2 hours ago, formatzero said:
Just said lean bank 2 ! No other codes were present.
Check for any vacuum leaks. Also check the exhaust gasket between the manifold and Catalyctic converter. if it’s leaking it could be the cause of the issue.
Have a read here
