DarkForce Posted November 11, 2019 Share Posted November 11, 2019 Having some severe issues with my 2005 350GT (identical to the 350z VQ35DE) happened straight after an oil change(I purchased the same oil/filter as last 10 services) had a CEL and a p0021 error, car in limp mode, change the front VVT solenoid and a cam sensor(B2). Car is running really rich (17MPG) every since and struggles/sluggish. Cleaned the throttle body and changes the air filter, and did an idle relearn and no change, it came up with a P0340 cam sensor fault/CEL a week later..changed the cam 1 sensor and the car struggled to start(long crank, poss dodgy sensor(....not sure it was a bad oil change that caused the original fault or someone worse (timing chain?) Can anyone recommend a reliable garage in Manchester? Don't want to end up with work/replacing parts without fixing the issue.... hope someone can help! Quote Link to comment Share on other sites More sharing options...
veeg33 Posted November 11, 2019 Share Posted November 11, 2019 A few of us goes to Lockwood & Greenwood, took my zed there for big jobs. https://www.lockwoodandgreenwood.co.uk/service/ Quote Link to comment Share on other sites More sharing options...
MONKEYSOCKS Posted November 11, 2019 Share Posted November 11, 2019 +1 lockwood & Greenwood Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted November 11, 2019 Share Posted November 11, 2019 +2 Lockwood and Greenwood. They've looked after my zed for the past 11 years. They have a courtesy car available if prebooking work in. If your car is lowered, be wary of the entrance. The left side has a dip. Approach from the right half Quote Link to comment Share on other sites More sharing options...
DarkForce Posted November 13, 2019 Author Share Posted November 13, 2019 Will give them a go, thanks all Quote Link to comment Share on other sites More sharing options...
