AlexRussell99 Posted October 30, 2019 Share Posted October 30, 2019 (edited) Hi, after some advice, I am currently looking at a Z that has had a forged engine and wondered how much power it is good for, if anyone knows a ballpark figure. Forged engine by Z1 Motor Sport consisting of .... Wiseco pistons piston ring set. eagle rods with cap with optional super A Carillo rods. Nissan OEM gasket kits ( cosmetic head gaskets). ACL Engine bearings ( rod main thrust ). ARP Head and main stud kits. Z1 Viton Valve Seals. Z1 Plenum spacer. Organic fast road clutch. Thanks Alex Edited October 30, 2019 by AlexRussell99 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 30, 2019 Share Posted October 30, 2019 500 - 700 bhp depending on how good the forge build is. However all that is futile if the tune is not good. 1 Quote Link to comment Share on other sites More sharing options...
itsLeon Posted November 29, 2019 Share Posted November 29, 2019 Well the Z1 Plenum spacer is kinda useless if you go turbo/supercharger. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted November 29, 2019 Share Posted November 29, 2019 On 30/10/2019 at 11:06, AlexRussell99 said: Hi, after some advice, I am currently looking at a Z that has had a forged engine and wondered how much power it is good for, if anyone knows a ballpark figure. Forged engine by Z1 Motor Sport consisting of .... Wiseco pistons piston ring set. eagle rods with cap with optional super A Carillo rods. Nissan OEM gasket kits ( cosmetic head gaskets). ACL Engine bearings ( rod main thrust ). ARP Head and main stud kits. Z1 Viton Valve Seals. Z1 Plenum spacer. Organic fast road clutch. Thanks Alex Steer clear away, the invoice he has for the work done on the engine is fake. Quote Link to comment Share on other sites More sharing options...
AlexRussell99 Posted December 1, 2019 Author Share Posted December 1, 2019 On 29/11/2019 at 15:55, Adrian@TORQEN said: Steer clear away, the invoice he has for the work done on the engine is fake. Hi, I was looking at this and I have also discovered this. Thanks for the message, I may alert the Facebook group with my suspicions Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted December 2, 2019 Share Posted December 2, 2019 On 01/12/2019 at 18:26, AlexRussell99 said: Hi, I was looking at this and I have also discovered this. Thanks for the message, I may alert the Facebook group with my suspicions My pleasure. I've confirmed with Z1 several times, 100% forged invoice. Quote Link to comment Share on other sites More sharing options...
Ian Posted December 2, 2019 Share Posted December 2, 2019 On 29/11/2019 at 13:20, itsLeon said: Well the Z1 Plenum spacer is kinda useless if you go turbo/supercharger. Errr no it’s not. Quote Link to comment Share on other sites More sharing options...
itsLeon Posted December 3, 2019 Share Posted December 3, 2019 (edited) 13 hours ago, Ian said: Errr no it’s not. Can you explain why it would be beneficial for an FI? The reason you would put that on an NA car is to improve the volumetric efficiency or so it claims. With a good modern turbo that starts generating boost at around 2500rpm the improvements to your volumetric efficiency with the spacer would be so small if at all that i would personally save the money for a good drink. But thats just me. Edit: So i did a whole lot more theorycrafting and talking about plenum spacers and FI and we came to the following conclusion. If you can increase the CFM of the plenum with a plenum spacer and will not hit an obstruction like the heads/cams than you might see an increase in power output this is for both NA and FI. I will stand by my earlier argument that you won't see better performance on an FI car with a spacer. But that is based on that i can't find any dyno run on an FI car with and without plenum spacer and i yet have to find all the CFM numbers on the plenum with or without spacer. Edited December 3, 2019 by itsLeon Quote Link to comment Share on other sites More sharing options...
