Bullet Posted October 10, 2019 Share Posted October 10, 2019 I've just replaced my clutch and i'm aware that bleeding the clutch slave is a pain so i left it alone. Although after refitting i have no pedal pressure at all. Quote Link to comment Share on other sites More sharing options...
zelda Posted October 10, 2019 Share Posted October 10, 2019 (edited) If no pedal pressure you need to bleed as per service manual procedure. Its actually not that hard if you read the steps through beforehand. It's doable with 2 people but easier with 3. The third person can check the fluid reservoir and make sure it doesn't run dry. I'm sure some heroes on here can do it alone but for me at least the extra help made a big difference. Edited October 10, 2019 by zelda Quote Link to comment Share on other sites More sharing options...
mr v6 Posted October 11, 2019 Share Posted October 11, 2019 Did you open the hydraulic system, as in change the slave cylinder or CSC, depending on your setup? Quote Link to comment Share on other sites More sharing options...
Bullet Posted October 12, 2019 Author Share Posted October 12, 2019 On 11/10/2019 at 17:22, mr v6 said: Did you open the hydraulic system, as in change the slave cylinder or CSC, depending on your setup? Nope, i didn't touch it. I thought if i left it alone i could just put it straight back on, Guess not. I've just bought a master, slave and braided line from Torqen, Quote Link to comment Share on other sites More sharing options...
