Passenger Window Reset - Fail!
EvansJD2112
Hi
Noticed this week that my passenger window is not returning when closing the door.
99% of the time, it's just me in the car so very rarely is the door opened.
No probs I thought, just do the reset - done a few times on my last 370z and the 350z before.
This time, damned if I can get it to work.
Tried the fully up, fully down, hold 3s, fully up (as per the manual)
Tried the fully up, hold 15s, fully down, hold 15s, fully up
...and various others I've found with Google (all with ignition ON rather than engine running)
The procedures definitely do something - sometimes the window stays up when opening the door (ouch), other times stay down and I have to hold the button to close.
Before I resort to getting the car booked in... any suggestions ?
2018 GT Auto
thanks
Edit..
Also just tried below.
Had to reset the drivers window after disconnecting battery, that was ok. Passenger window still refusing to play ball.
ADDITIONAL SERVICE WHEN REMOVING BATTERY NEGATIVE TERMINAL : Special
Repair Requirement INFOID:0000000004460995
The following specified operations cannot be performed under the non initialized condition.
• Auto-up operation
• Anti-pinch function
• Key cylinder switch power window function
• Automatic window adjusting function
INITIALIZATION PROCEDURE
1. Disconnect battery negative terminal or power window switch connector. Reconnect it after a minute or
more.
2. Door switch is OFF (close).
3. Turn ignition switch ON.
4. Operate power window switch to fully open the window. (This operation is unnecessary if the window is
already fully open.)
5. Continue pulling the power window switch AUTO-UP. Even after glass stops at the fully closed position,
keep pulling the switch for 3 seconds or more.
6. Initializing procedure is completed.
  • 3 years later...
Hi, process should work.
turn ignition on, don’t start the engine.
open window and keep button down for a few seconds
close window and keep button up for a few seconds
worked for me following a flat battery
